Question about HP OfficeJet Office Equipment & Supplies
Hp officejet j4650 - OfficeJet HP Office Equipment & Supplies
Ink cartridge will not lock into place
Hi Cynthia..are the taps broken on the carriage where the cartridge goes...???? color one on the left and black on the right.
Is that model right......a "J4650"
Apr 13, 2014 | HP OfficeJet Office Equipment & Supplies
I LOST MY Hp OFFICEJET J4580 ALL IN ONE PRINTER DRIVER CD. SO THAT I CAN NOT INSTALL MY Hp OFFICEJET J4580 PRINTER IN MY ANOTHER COMPUTER. SO I WANT TO DOWNLOAD THE DRIVER.
You can download the drivers for any of your HP products from HP's support site (www.support.hp.com)
For your HP J4580 AIO officejet printer you can download the driver from the following link by selecting your Operating system.
Driver for HP J4580 AIO officejet
Thank you for choosing Fixya
May 27, 2010 | HP OfficeJet J4580 All-In-One Laser...
How can i install my printer HP officejet 4355 without the CD
You can try downloading the "full-featured" software for your OfficeJet 4355 from HP support: (choose your operating system)
HP OfficeJet 4355 Downloads
Jan 04, 2010 | HP Officejet 4355 All-In-One InkJet...
Whant to buy Hp 88 Printhead
From the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/product?product=501369&lc=en&cc=ca&dlc=en&lang=en&cc=ca
click "Shop For Supplies" to access:
https://h30042.www3.hp.com/SureSupply/
Which of the HP 88 cartridges:
C9385AN HP 88 Black Officejet Ink Cartridge
C9386AN HP 88 Cyan Officejet Ink Cartridge
C9387AN HP 88 Magenta Officejet Ink Cartridge
C9388AN HP 88 Yellow Officejet Ink Cartridge
do you need to order?
Nov 20, 2009 | HP OfficeJet Pro k550 Printer
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
I need to see a user manual for hp officejet v 45 all-in-one
GO ONLINE AND ASK FOR IT
HP OFFICEJET 6210 USER MANUAL
OR
HP OFFICEJET 6210 SERVICE MANUAL DRIVERS
OR
HP OFFICEJET FOREM USER GROUP
OR
WWW.HP.COM/OFFICEJET
ROD
Feb 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Drivers
i lost my hp 4355 officejet printer all-in-one drivers cd
Apr 14, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
96 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
