My built in camera does not function (lifeframe, skype, YM, virtual camera : ASUS N53S; OS- Win7Premium.
I have an installer but when I try it, please insert disk. The disk is labeled : Windows Vistax64.
  • 3 more comments
  • Michelle Jan 16, 2013
    thank you for your suggestions. however, i did everything you instructed @ Mr Sullivan but my built in camera still not working. i have checked the device manager, it states that it is working properly. i do not know what to do. i have checked the installer disk, chose the software for Camera, but no installer. Full description : USB Video Device: PID_1718.
  • Brian Sullivan
    Brian Sullivan Jan 16, 2013
    Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call.
  • Michelle Jan 17, 2013
    cannot detect webcam.. i do not know what happened to my built in camera.
  • Brian Sullivan
    Brian Sullivan Jan 17, 2013
    What type of laptop ?? Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. If it doesn't If your webcam breaks, you can replace it instead of buying an external webcam that you have to carry around and remember to attach to your computer every time you want to use it. Disconnect your computer from all electrical outlets, close all programs, shut it down and remove the battery. Remove the screws from the bottom of your laptop until you are able to remove the outer casing and set it to the side. Remember where each individual screw belongs because not all tin screws are created equal. Try laying out the disassembled elements in a pattern to remember where everything goes. Remove the motherboard and keyboard if necessary. The goal is to be able to detach the top part of the laptop from the bottom section, and removing these elements may give you the necessary access to do that. Remove these elements by carefully taking out the screws and disconnecting the necessary delicate wires and cables with your fingers. Once again, remember where everything goes so your laptop will work correctly once you reassemble it. Disconnect the top part of your laptop from the bottom by disconnecting cables that connect to the screen from the motherboard. Separate the outside casing of the top part of your laptop by using the plastic putty knife to pry it open or by removing more screws. Locate the webcam and find where it attaches to the rest of the laptop. You may have to remove more parts in order to access the entire webcam assembly. http://www.youtube.com/watch?v=0o3y8U0wq... Dell Studio-1535/1536/1537 | LCD Web Cam Camera Replacement
  • Michelle Jan 19, 2013
    N53SN Asus; Os: Win7 premium service pack 1 ; CPU: Intel i7 2630QM; webcam details: driver version 6.1.7601.17514; usb video device PID_1718.... thank you so much for taking time in answering my query.
  • Computers & ... Master
  • 27,725 Answers
If this is a web cam problem ?
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Posted on Jan 15, 2013
danasaur
  • 77 Answers
SOURCE: Asus Lifeframe
The most common "other program" that interferes with camera download process is your antivirus program. Right-click the AV icon on bottom right and select EXIT, then wait 30 seconds or so, and try running the camera application again. Let me know if that was it.
As far as the second question, you can change boot.ini by r-clicking "My Computer" and selecting "properties'. Then select the startup and recovery tab, and you will find a boot.ini editor. Also, here is an MS article that explains how to directly modify boot.ini with notepad/wordpad:
http://download.microsoft.com/download/a/f/7/af7777e5-7dcd-4800-8a0a-b18336565f5b/BCD.doc
Posted on Feb 14, 2008
SOURCE: Cannot start Asus Lifeframe
hello there im using vista and i cant get lifeframe 2 to load up when i try it till me its stoped working any idears thank you
Posted on Oct 02, 2008
mspcrepair
  • 169 Answers
SOURCE: Installing Windows Server 2003 on a preinstalled Vista OS
The reason it is showing "no hard disk" is because you have a SATA hard drive, and there is no SATA support on the WS2003 software, so it doesn't even "see" the drive when trying to install.
What you can do is download SATA drivers for your hard drive to your machine. Once downloaded and/or extracted, restart the installation but choose F6 to load "SCSI or 3rd party drivers", then point to the downloaded drivers.
Your installation will then load the SATA drivers, thereby recognizing the hard drive and you'll be able to successfully install Windows.
Hope this helps - remember to rate :)
Posted on Oct 06, 2008
myrlex
  • 674 Answers
SOURCE: windows XP , system goes to sleep immediately after booting.
CHANGE THE CD OS IF YOU HAVE ANY AVAILABLE SOME FILE NEEDED IF YOU KNOW HOW LOCATE THAT FILE DOES'NT MATTER BUT THE PROBLEM IS YOU DONT KNOW HOW LOCATE..
PROBLEM FROM THE CD INSTALLER
Posted on Jun 25, 2009
  • 1570 Answers
SOURCE: hi im trying to install windows 7 on my aspire
Hi there !
Your windows operating dvd installer is damage. It just the CD/DVDROM drive cannot read your DVD installer because it have too many scatches in your DVD. Just get new OS dvd installer and repair your windows 7 operating system or reinstall the operating system.
Posted on Jan 26, 2011
How do i open the camera on my asus k53e
If the WEBcam driver is not installed then download and install it.
You can download the WEBcam and device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 14, 2013 | ASUS K53e B1 Notebook
Inverted web cam display in asus k401j
1. Download the latest Chicony (or Suyin) driver for Windows 7. Check here: http://support.asus.com/Download.aspx?SLanguage=en&m=Camera&p=3&os=)
2. Extract contents to desktop.
3. Click the ORB button. right-click on Computer and select Properties.
4. Select Device Manager.
5. Click on Imaging Devices to show the name of the webcam.
6. Right-click on the name of the webcam and select Properties.
7. Go to the Driver tab. click on Update Driver. a new window should pop-up.
8. Click 'Browse my computer for driver software'. select 'Let me pick from a list of device drivers on my computer'.
9. On the next window, it'll give you the current driver. click 'Have Disk'. click Browse. Browse to the desktop and select lastest driver that you've downloaded. it'll be then added to the list of drivers. select the new driver and click Next. Just follow the prompts so that it'll install the new driver.
If still this does not work, try this:
Re-install the camera virtual camera using your ASUS hardware disc and follow this step.
1.Insert ASUS hardware disc and "open"
2.Click "explorer"
3.Click "software"
4.Click "camera", then choose and click chicony folder
5.Open the folder APPLICATION/installer, and re-install the ASUS virtual camera.
Once you already installed the driver, go to start menu click or type ASUS lifeframe then open it.
Jun 25, 2011 | ASUS Computers & Internet
Asus virtual camera not working
have you tried pressing Fn+V keys? V key has a camera icon and when Fn key is pressed together with it, Asus lifeFrame utility opens. Only then your webcam will be activated. Enjoy!
Apr 27, 2011 | ASUS K42F A1 Notebook
I am a first time user of ASUS virtual camera. Can you provide me with instructions on how to turn it on and off?
Hi kathy_handra,
You can turn on and off the ASUS virtual camera by pressing the FN+V. The Virtual camera uses software called ASUS lifeframe. You can locate and launch it by looking under the ASUS utility group of Icons for Lifeframe. When you open the application it is usually set to video mode. So, to switch it to camera click on the camera icon which is located at the lower left circular menu. To locate the photos, you will find them in your document folder [Documents\ASUS\LifeFrame\Image].
Hope it helps.
Thank you for using FixYa.
Apr 08, 2011 | Computers & Internet
Asus camera not working
Go to start and search for Asus virtual camera. right click asus virtual camera. go to properties. click the compatibility tab. and click the box that says run in 256 colors.
problem solved =)
Mar 20, 2010 | ASUS M51Sn-C1 Notebook
Asus Webcam constantly being used by mystery application
Built in webcams are not the easiest to troubleshoot as its difficult to reboot the webcam software.
With my plug-in I can just disconnect it for a couple of seconds to reboot it and clear the previous program.
Its not unusual for webcam software to remain hooked up to a program even after you exit it correctly.
What is unusual with yours the webcam comes on when you start your computer.
You might try to disable your webcam and then enable it again in the 'Imaging' folder of your Device Manager to see if the webcam light goes off and remains off when you enable it again.
You should be able to see where the webcam is being used by launching your Task Manager and hitting the Application tab.
Hope you can get your problem sorted and post some information on it for future reference
Dec 06, 2009 | Computers & Internet
I have just bought my Asus notebook and I want to start using my built in webcam with friends, but I don't know where and how to start.
see if there's a asus lifeframe software installed in your notebook. i have the same notebook and whenever i want to use the built in webcam i use lifeframe.
in case you don't have try downloading it.
http://asus-lifeframe.software.informer.com/
Dec 03, 2009 | ASUS Eee PC 1000H Laptop
Many people are reporting this same problem. If you have downloaded and installed Lifeframe 2, and updated the Bison camera drivers, and it still freezes, you're not alone.
Some people have just uninstalled Lifeframe and use the Windows Camera and Scanner program instead. It's worth a try.
And get some antivirus software!! Use Kaspersky if you don't want to buy McAfee or Norton. It's too dangerous out there to not have anything.
Jul 11, 2008 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
