Question about Imation Computers & Internet
How do i format apollo m100 usb3 1t to FAT32 on IMAC
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
Feb 16, 2014 | Imation 160GB Apollo 2.5" Portable USB 2.0...
Imation Apollo M100
https://www.imation.com/en/consumer/external-hard-drives/ External Hard Drives
Jan 29, 2014 | Imation Apollo UX 2.5" USB Portable (250...
I just purchased a StoreJet 2M 320 GB drive. I would like to format it for use with my iMac. The MAC software doesn't seem to have a solution. How do I format the drive?
When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it using a computer with Windows OS. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows).
Jul 06, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Does My Book 3T need to be specially formatted for an iMac?
The Mac can read FAT32 and NTFS (with NTFS-3G), so, no, it does not need to be specially formatted for iMacs.
Jun 24, 2011 | Western Digital 3TB My Book Essential USB...
Hi, I had problem using Imation 27390 apollo expert ux. The hardisk is in NTFS format, and work perfectly fine when i plug in computer with Windows Vista and 7. But it cannot be recognized by computer...
Windows XP has limitations on recognising too large NTFS disks. One of the solutions would be to format the entire disk as FAT32 or make a partition and format that as FAT32.
Feb 28, 2011 | Imation 27390 Apollo Expert UX 2.5" 320GB...
My iMac doesn't recognize my simpletech 160gb, but my PC does. Trying to get the hard-drive to work on the iMac.
Most likely it's formatted in NTFS which the Mac supports only with an addon, that you don't have.
The easiest way to fix that is to format the Simpletech in FAT32.
Dec 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Can I connect my apollo 2250 to my old imac?
OS X drivers for the Apollo 2250 apparently exist only in 10.5 and 10.6, both of which your iMac G4 is too old to run.
If you have this printer attached to another computer on your home network, you could activate printer sharing and allow your G4 to print to it that way.
Mar 11, 2010 | Apple iMac G4 Desktop
Which Portable hard drive can be used with both a Windows PC and an Apple iMac please
Hello
Well, you can basically buy any external drive and it will work on both operating systems if you format it to a FAT32 format.
If you buy a new drive, you first need to delete the partition on the new drive using Fat32 formatter, and then format it in Fat32 file system.
Here is a link to where you can download the software for free, and get instructions on how to do this.
http://tokiwa.qee.jp/EN/Fat32Formatter/
Hope this can help.
Kind regards
Andrea
Nov 16, 2009 | Seagate 250GB 7200RPM ATA DVR Drive:...
Maxtor one touch mini 120gb drive won't show on my imac.
if the drive has been formatted in NTFS then the mac will not pic the drive up, you have to format the drive in FAT or FAT32 for OSX to pick it up and use it. See if this helps, if not the drive may be faulty
regards
Nov 21, 2008 | Computers & Internet
Computers & Internet Logo
187 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
