Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
F 13 error message
My washer will start but no water comes in--eventually we get an f13 error message. HELP!
    President:
  • 878 Answers
Rocky, the F13 has to do with the dispenser motor. It's unable to move to it's home position. You will need to remove the top by removing the 3 torx screws in back. Slide it off toward the back. Check the linkage from the dispenser motor to the top of the dispenser. Check the harness from the dispenser motor to the central control unit. Reseat if necessary. At the main board in back, third harness from the left is the dispenser switch/motor. Wires read 6-5-3-1 from left to right. Ohm out the switch, test points 6 to 5 should read 0 ohms. The motor 3 to 1 should read 1400 ohms. Catriver.
Posted on Jul 10, 2007
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
I have an error f13 could you help me?
Generally the F13 code refers to a water inlet problem, I would get the inlet manifold valve checked, or stating the obvious, is the water turned on and make sure there is no restriction in the hose behind the machine.
Nov 09, 2014 | Hotpoint-Ariston ARWDF129NA Washer
Bauknecht wae8999 washer machine error codes f13
F 13 is a water distribution problem ... poss filter blocked ..
Oct 02, 2014 | Washing Machines
Wdd960 f13 error code
you could have a problem with the fill valve,shut the water supply off,remove the hoses from the back of washer and mark them so you put them back the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses you'll know it's the washer and not the house water valve.if water comes out look into the washer valve where the hoses connect,if you see alot of junk on the screens change the water valve.i want to tell you that i haven't worked on this machine yet,i looked up your error code and it sounds like you're having water issues from what i've read,there's a tech sheet in the washer sometimes down near the bottom cover or taped onto the side wall,it will have all the error codes and tell you how to run the machine in a diagnostics mode to check everything in it,also next time you write in send the full model number off of the machine you're having problems with so whoever is trying to help you can look up your machine,usually you open the door and look around the opening where the door closes in and you should see a tag with the model and serial numbers.hope this helps,best thing to do is find the tech sheet and run it in diagnostics
Jun 23, 2013 | Washing Machines
Washer was just moved to a new house and doesn't work. It has F-13 code.
F13 Dispenser circuit error
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 02, 2011 | Washing Machines
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
My code is f13
Remove you base panel and hunt for your tech data sheet. A list of the codes and solutions is given along with diagnostics. atypical F-13:
the dispenser.
Dec 15, 2010 | Washing Machines
I have error code f13, can you help, please..
This s is how i fixed the F-13 Fault on my Hotpoint WD 640 washer dyer. Simple to fix just see the pictures and explanation. Hope this clears things up
Boxie
1_7_2013_12_28_59_am.jpg1_7_2013_12_29_33_am.jpg1_7_2013_12_31_38_am.jpg1_7_2013_12_31_56_am.jpg
Aug 07, 2010 | Dyson Memory CRO1 Front Load Washer
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
320 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
