Question about RCA R52WH73 Projection Television
RCA CONVERGENCE PROBLEM
I have the RCA model R52WH74 chassis ITC222A and i'm having the convergence problem with the 3D effect and picture bends in the middle. My question is to repair this problem do I only need to replace the fl231 fuse or the convergence board or the convergence power board or the dl231 diode or any combination of these. Also I've read to resolder the Flyback do you think this is correct? Thank you so much in advance for your help.
    Sergeant:
    Champion:
  • 346 Answers
Check and or replace dl231, fl231
Posted on Jan 27, 2009
The picture looks 3D and when you select the menu all writing is in a U shape. The TV is a RCA HDTV and the model # R52WH74YX51. Serial #G402C10DZ, chassis #ITC222A, and was manufactured Oct. 2006.
Its more than likely the FL231 fuse has blown due to carcked solder joints on the flyback. very famous issue with that model if the auto convergence feature is no longer listed under the setup menu then you will need the convergence option missing repair kit from www.tvrepairworld.com
Aug 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have 3d on my 52 inch rca and go to set up convergence isnt there now.is this something i can fix?
Yes its a easy an inexspensive repair. www.tvrepairworld.com has the ITC222 and ITC222A convergence option missing repair kit. The kit contains the parts and CD with instructions.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
Where is the convergance amp?
Accros the top of the chassi.conv power supply is to the left
Apr 23, 2009 | RCA HD52W58 52" TV
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Rca model r52wh74
You could get into service mode and set the convergence. The only problem is....RCA decided to remove it from the menu for the R52WH74. It only runs 1 time during the first setup, according to RCA Customer Service. This is the 2nd one I've bougt in 6 years. Enough RCA Garbage!
Dec 02, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
RCA R52WH73 Projection Television Logo
633 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
