How do you light the pilot light on vulcan compact 60? there is no ignotion button to be seen
  • Chris Herft Apr 12, 2015
    Sorry renee - no answer to this. :-(
    New Friend:
Hi. did you manage to light your pilot? I am having the same problem and its getting cold. Can you possibly tell me where the pilot light is on this unit? Thanks :)
Posted on Apr 12, 2015
Testimonial: "sorry Shae; no answer to this one :-("
Hi chris, did you work out how to light the pilot light! the instructions are great until it says light the pilot.... yeah, but where is the pilot light?? it is easy to find when it is on... but not obvious when off... i\'m pressing the button in for 15 seconds and then waving around a naked flame... it just doesn\'t feel safe after 30 seconds of gas wissing and no joy... plus i\'m in a crawl space under my apartment covered in spider webs - i\'d love another clue so i can get out of the crawl space quicker ;-) thanks ren
Posted on May 05, 2013
Testimonial: "sorry renee; no answer to this one :-("
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
Need to know where to light pilot
Normally, it's under the fryer, inside the door...The issue almost always is you have to press the button down long enough for the sensor to tell the fryer to light....There are 3 or 4 burners in the bottom of the frypot on top and under the fryer is the pilot to light these all up...Look for the gas valve, turn the gas valve to pilot, and press and hold it down, put flame to pilot and release button when flame is self standing... Then turn to on position. If you have other issues, call the Vulcan company themselves, and they will help you further.... Susan Restaurant Equipment Outlet, Cinc, Oh www.restaurantequipmentinc.com
Aug 20, 2011 | Vulcan EF3 Deep Fryer
I have a Vulcan Gas wall furnace that is not working. We cannot work out how to light the pilot light. According to the documents we have it is a 26.4MJ model or the 40MJ model
The Quazar manual says....
-Thermostat control knob to 0
-Then press and hold down * (Star) button
-The press the "ignition" button one or more times until the pilot lights
CONTINUE to hold the * button for at least 15 seconds and release slowly making sure the pilot stays lighted.
-If the pilot goes out.. repeats steps above and hold the * button for much longer than 15 seconds and THEN release the * button slowly.
Kelly
May 06, 2011 | Heating & Cooling
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
The pilot light of my Vulcan Compact 60 Airconditioning unit can be lit but will not stay alight.
Hi.
Air duct must be checked. Poor ventilation is common cause for the problem.
If ventilation is OK, then the other possible cause is a defective flame sensor. The flame sensor is connected in parallel with the valve solenoid. For safety reasons testing must be done by a technician.
To get a quote on repair ring the service number listed on the user manual.
Sep 13, 2010 | Heating & Cooling
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Heating & Cooling Logo
779 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
