Belkin n450 dual band n router setup hughesnet
Not a place on my hughesnet modem to plug networking cables
bee2busy
  • 51 Answers
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Posted on Feb 23, 2008
rickyostrom
  • 274 Answers
SOURCE: Surfboard Cablemodem not communicating with Belkin Wireless Routr
If the modem is actually passing out DHCP, then you have to connect the modem to the router 4 port lan side and not the wan port. Give the router a static ip like 192.168.1.2 and you can talk to it and configure the wireless features.
Posted on Feb 17, 2009
  • 23 Answers
SOURCE: 3800HGV-B and LinkSys Dual-Band Wireless-N USB Network Adapter
Because the linksys is talking about SecureEasySetup which most lynksys routers use. The 2wire 3800HGV-B button is not a SecureEasySetup button.
Posted on Mar 18, 2009
SOURCE: Cannot connect Belkin F5D8233-4 Router to Mac Laptop
Hi, I had the same problem with my MBP and the best solution I found was:
Dissable the Wlan security and use Mac Address control only for the wireless. This will keep your network secure anyway and you can connect normally.
The only inconvenience is that when you want to connect other computers to your wireless you have to enter its MAC address on the list.
Remember to set the list as Allow.
Posted on Apr 28, 2009
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
Posted on Jun 12, 2009
I have an HP desktop that runs VIsta that will connect to my wireless router but not the internet.
    , click All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. securityshield.jpg
    If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. At the command prompt, type the following command, and then press ENTER: netsh interface tcp set global autotuninglevel=disabled
    This command disables the Receive Window Auto-Tuning feature.
  4. Close the Command Prompt window.
  5. Restart the computer.
  6. Also try here
How to Fix Local Only or Limited Connectivity in Vista
Jan 22, 2014 | Belkin Components Belkin N450 DB Wireless...
I have a 2wire and a wireless router Belkin34e. I cannot get the preception I need to watch my movienite streaming media player. I have a tv upstairs and downstairs and the preception is poor for bothl.
The best is to use an Ethernet cable.But if you cant wire up you will need that one of your device be downstairs.In order to do it you need to configure one of them as an access point bridging one router to the other.Or get a Wireless Extender that is a hardware devices that act as either bridges, allowing you to connect a wired device to a Wi-Fi network without need for additional cabling or networking configuring, or they act as repeaters, extending a wireless signal beyond the normal bounds of range.
Apr 11, 2013 | Belkin Components Belkin N450 DB Wireless...
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
HN9000 DSL and RangeMax Wireless not connecting wireless laptop
uninstall then reinstall wireless card drivers then reconnect.
Jul 26, 2009 | NetGear MR814 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Cant get online wireless'ly
The procedure is 1st. to connect the LAN cable to the router (not to the LAN port marked WAN) and use the browser to configure the Belkin router for the wireless settings.
In the wireless setup change the SSID from the default SSID to what you like., set up encryption (if your wireless card supports WAP then use WAP encryption, if not use WEP 128bit)
Also change the administrator password (write it down and put it in a safe place).
you can disconnect the LAN cable from the computer and router.
If you had not installed the wireless driver for you wireless card, do so now.
Connect the LAN cable to the WAN port on the router and the other end to the Hughesnet.
Now configure the wireless card with the SSID and the encryption that was set on the router.
If all goes well you should see your router and get on to the Internet.
Get back to me with error messages if you have problems.
May 22, 2009 | Dell Inspiron 4150 Notebook
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
