Question about JVC AV-27020 TV
Volume will not stay up
The volume will not stay up. When you try to turn the volume up the tv automatically turns it down. When you press the volume(-) key the tv turns off. The power keys turns on and off as normal. Can anyone help me with this problem?
  • 93 Answers
Replace your tact switch ,the switches that are in your panel board of your tv.
Posted on Oct 18, 2007
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
Black screen
Master reset with hardware keys A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloaded content, ringtones, images, apps, and contacts. It does not delete data stored on the SIM card or SD card.
If the device menus are frozen or unresponsive, you can master reset using hardware keys. To perform a master reset, follow these steps:
  1. Back up all data on the internal memory. You won't be able to since there is no display.
  2. Turn off the phone.
  3. Press and hold the Power and Volume Up keys simultaneously.
  4. Continue to hold the keys past the T-Mobile splash screen.
  5. Release all keys when the Android system recovery screen appears.
  6. Press the Volume Down key to highlight 'wipe data/factory reset.'
  7. Press the Power key to select.
  8. Press the Volume Down key to highlight 'Yes -- delete all user data.'
  9. Press the Power key to select. The unpacking Android screen appears, and once complete with the reset, the Android system recovery screen reappears.
  10. Press the Volume Down key to highlight 'reboot system now.'
  11. Press the Power key to select. The phone will automatically restart.
Mar 13, 2014 | T-Mobile Prepaid Prism II
Need code for urc-3605 for bell express vu satillite
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 16, 2010 | One For All URC-3605 Remote Control
I need 3 digit code for my Prima tv to program bell express vu
Dec 16, 2009 | Prima C2012 TV
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
Dec 07, 2009 | Televison & Video
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Samsung 37
It sounds like your TV is set at Shop Mode. To veify that turn on your TV and press the info button on your remote, some info will be displayed, If Shop Mode appear please follow the next steps...
In order to change that mode turn on your tv, press the volume key (either one) on your front or side panel (Depends of the model you have) the volume bar will appear, once this happend press the menu key on the front or side panel and hold it for like 7 seconds, "Dynamic" symbol will appear at your screen this means that you are not longer at Shop mode. You can double check by pressing info button at your remote
Regards
Jan 14, 2008 | Samsung LN-T4665F 46 in. LCD Television
Code for satellite bell (expressview)
Jan 03, 2008 | Televison & Video
JVC AV-27020 TV Logo
427 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
