Question about Kitchen Ranges
GE range - oven stopped working after cleaning
The rastove/oven worked well until last week . I lifted the bottom heating element to clean out the grease at the bottom. After that, only the top heating elements worked (all gas stoves and all oven fans work).
Today, I tried to check for loose connection by taking out the bottom heating element and puttng it back. After that both heating elements sttopped working and the oven heating light does not light up! Convection and broiler fans still work.
What should I do?
  • dominicchang Jan 24, 2009
    Dear Mark,
    Thanks for the tip. But now how do I get about checking the fuse and tripped breaker? Where are they located?
    Thanks and best regards
    Dominic
    President:
  • 1,214 Answers
If you bent the bottom element out list out of the way, you may have broken the actual heating element inside of the metal sheath. Or, it could have shorted to ground.
After tinkering with it more, you might have caused another short, and now both legs of 220 VAC have either a blown fuse or tripped breaker.
Reply what you find is the sondition, and I will help you troubleshoot more.
Posted on Jan 24, 2009
  • Mark Egan Jan 24, 2009
    Check the fuse or breaker in your electrical panel for the house, for that circuit. It will be a double breaker, or two fuses that should be side by side.
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
The preheat light flashes on my he range and oven does not heat. I have had the sensor checked and its working. What else could it be?
Most likely the heating element is bad. Disconnect the oven from power. You can open the bottom of your oven to expose the heating element and see if there are any signs of burns or melting. If you can, remove the heating element and use a volt/ohm meter to check "continuity" across the element ... it should be a dead short. While performing this inspection, confirm that the wires and connectors leading to the heating element are intact and connected.
Oct 28, 2014 | GE 30" Self-Cleaning Freestanding Electric...
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Need to replace heating element
We have a maytag stove and we cleaned our oven on the self clean cycle a week ago. I used the oven once since we cleaned it. today we went to use the oven again, and the oven will not heat and the broiler will not come on either....seems funny that both would quit working at the same time.....any suggestions....
Dec 05, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
295 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
