Question about RCA Televison & Video
Whats skip mean?
I bought a used TV with a remote. It has a SKIP button, whats it's function?
It allows you to skip that channel when surfing using the up and down channel buttons. You can still punch the channel in with the number pad to get to it though.
Posted on Jan 24, 2009
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
www.hivmr.com/db/k37cmjfzkk71s913ksf3j7xfxsz3zc37
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Dec 28, 2015 | Televison & Video
I get a download message telling me to hit main for three seconds or skip. When I hit main nothing happens and when I hit skip the remote freezes. Cannot perform any functions and unable to change...
check your batteries to make sure they are good. if they are good you may need to default the remote and reprogram. if this doesn't fix it you will need another one
Jun 08, 2014 | Universal MX-450 Remote Control
RCA XL 100 Commercial Skip TV
Only thing I can think of here is to get a Universal remote, then try these pins to Sync your TV with URM:
RCA - 000,003,004,005,007,009,011,015,048,082,092,094,
096,098,101,102,103,107,113,125,129,067,179,187,188,191,194
May not work 100%, depending on remote functions.
Instead of just buying any, you could maybe borrow one from a friend first of all.
Oct 11, 2017 | Televison & Video
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Remote will allow you to "choose an activity" to
Hi. It sounds like some of the IR commands on your remote (menu, exit, guide, info, play, skip, etc.) for your TV and DVD player are not correct. Luckily, the Harmony remote is a Learning remote, meaning you can use your original TV or DVD player remote to teach the Harmony remote the correct commands. The following tutorial by Logitech will assist you with this:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
Lost remote ans ended up deletde ch 3 what can i do,plus thr tv is rolling picture.can this be resolved without a remote
rolling of picture can be controlled by v.hold or vertical hold on your tv. some tv has has this control on the back side. if the control is there & it is not controlling the rolling of picture, that means the control is bad & needs replacement. to get ch 3 back: go to menu & try to find SKIP function, go to ch 3 & put off SKIP.
Aug 25, 2011 | Televison & Video
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
Can you tell me how to decode a grunkel dvd player to all regions?
Model 20-NT
1. Using the remote control, key in the following: Setup, Stop, Skip Backwards, Skip Forwards.
2. You should then be able to change region and remove MacroVision.
Turn on the DVD player without DVD inserted. Then, using the remote control, press this buttons: Setup, Stop, Skip Backwards, Skip Forwards.
Model 22NG
Turn on your player
Open the tray
Press 8 4 2 1 on the remote control --> "Region 2" appears on the TV screen
Press SELECT until 9 for region free & MacroVision free
Model 32S
Press Setup
press Volume +
Press Volume -
Press the right arrow until the screen on the player reads 255
Press setup to exit and all done
Nov 17, 2009 | Televison & Video
Commercial Skip Feature
When a commercial comes on, you press the "Commercial Skip" button on the remote. Then you see a 30-second countdown timer appear on the screen. If you think there will be more than 30-seconds of commercials, then press the button more (each time you press adds 30 seconds to the on-screen timer -- usually I press it 4 to 5 times). The timer stays counting down on the screen while you change channels during the commercials to see what else is on. When the timer counts down to 0, it is erased from the TV screen and the TV automatically changes you back to the channel it was on when you pressed the commercial skip button. I use this feature a lot! I wish all TV's had it built in. Some universal remotes have a similar (but more awkward feature) where the remote has the timer inside it, and it sends a signal back to the TV when the count is up, but I don't think this would work as well.
Oct 21, 2007 | GE 35GT740 35" TV
Televison & Video Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
