Question about Mitsubishi WD52527 52" Projection HDTV
Purple spot mitsubishi 62 lcd
I have a purple spot i call already but they say i need a new lamp but the tv is fine need help
  • 43 Answers
If the tv is in warranty get the lamp, ittl burn out after awhile anyway, if it doesnt fix it they will end up sending somone out, now if its outside of warranty get a free estimate from a repair center
on a side note if they havent made you pwoer reset it by unplugging it, give it a shot
Posted on Jan 24, 2009
SOURCE:
II HAVE A 65" MITSUBISHI TV MODLE WD-62530 JUST
move all other electronics away from the screen mine did it too
Nov 17, 2010 | Mitsubishi WD62527 62 in. LCD HDTV
The color is really dim,
i have a wd62528 62" dlp hdtv that shows a picture but very dim. I have tried numerous things including factory reset and checking the lamp. I started to get a new lamp but was told if i have a dim picture getting a new lamp will do nothing. However, Mitsubishi support said that if i have a dim picture but was not continuing to get worse or darker, then they were 100% sure i just needed a new lamp. I'm confused. Will a new lamp solve my problem or no. i would just buy and try but it is very costly. please help
Nov 02, 2010 | Mitsubishi WD-62528 62 in. LCD Television
KEEPS SHUTTING OFF
What type or TV is it DLP , LCD, Plasma?
DLP -----> LAMP--------->go to this 2 sites
http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi%20WD-62525%2062
http://www.discounttvlamps.com/mitsubishi-tv-lamps-s/20.htm
PLASMA------->Digital boar or On switch it depends ... can you go on the Display Menu and it looks goo?
do you see any spots?
LCD-------------> You need DMD Bord
good luck tell me more so we can figure it out!
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Lamp lcd
Make sure lamp door is properly on, there is a sensor on the door.
Sep 19, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Light purple spots on my screen
Unfortunately, this sounds like a problem with your TV's lamp. They are not cheap to fix. Search Ebay for a new lamp and get someone to install it for you. These Mitsubishis have a design flaw that make the lamps burn out quickly.
One thing that will PREVENT this problem is making sure that the TV's vents are clean.
Dec 29, 2008 | Mitsubishi WD-62528 62 in. LCD Television
TV does not come on
Similar problem with my Sony. Unplug for 36 hours from the wall and it fixed my problem
Dec 16, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi 62" projection LCD
dirt internal to the tv. suggest taking the screen off and removing the small rectangular panel in the middle and spraying off LCD panels located under metal fins. this should fix distortion.......for now.
Oct 31, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD52527 52" Projection HDTV Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
