Question about Dell Latitude D600 Notebook
Ssid network I just got a Dell Latitude D600 and I can't get rid of the settings for a ssid network I tried formatting -taking out the power plus setting it up with no modem and i am still getting the same message.Connected to a Default ssid network.How do I get rid of this problem I have a wireless system with a d link modem and I am using windows Xp.Any help would be great Thanks in Advance
  • hammertoes58 Jan 24, 2009
    It worked Thank You very much
  • Dell Master
  • 32,281 Answers
The SSID setting is part of the DLink wireless setting.
To configure the DLInk wireless/router from new, you may need to connect the DLink wireless/router the laptop with a 10baseT cable, then open your browser and enter the URL address http:/192.168.0.1 The default login = admin, no password required. Unless you have previously altered the default settings.
You should configure the DLink wireless with a different SSID from the default one and set it up with encryption preferrably WAP.
You should also setup a password for the admin login, so to prevent someone from hacking into your wireless/router to change your settings and steal your Internet access.
You would need to setup the wireless card in the laptop to have the same wireless/router settings eg. SSID and encryption.
You can now remove the LAN cable and connect to the Internet by wireless.
All this information is in your manual.
Posted on Jan 24, 2009
Replace dell d600 battery
I'm assuming that you mean the CMOS battery which keeps the date and time and configuration settings of your laptop. If so, here is a link to the location of the battery:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d600_service%20manual_en-us.pdf
Feb 06, 2013 | Dell Latitude D600: Pentium M 1.6GHz,...
How to restore to factory settings latitude D600
hi,
the d600 has a 8 pins chip,like the c600 where the pasword/faxtory
setting is stored..
it's located under the tape where the pcicma socket is..close to edge of the board
it sais:UPW1
I think you can use the paperclip methode like the c600
wich means short two pins ( 3& 6) while you power the lap
May 20, 2010 | Dell Latitude D600 Notebook
Hi, does anybody have an idea why my dell d600 and my d510 wont actually connect to a wifi network, it can detect them ok, but it just will not connect to it, i have tried new connections / ssid name /...
You need to remove all your existing preferred wireless connection from your Network and sharing Center by clicking the manage wireless networks and removing each one by right-clicking each and select remove.
In xp, open view available networks and click the change advanced settings and remove all existing preferred networks then try to connect again to the wireless network you're trying to connect.
May 21, 2010 | Dell Latitude D600 Notebook
Latitude X1 PC Notebook: I just used ny Dell Latitude X1 to add a new lapto...
If the other laptop can't see the network, then it sounds like you somehow turned off SSID broadcasting while you were in the router's settings. Log back into your router and look for the SSID broadcast enable setting. Make sure it is set to on, then save the changes and reset the router if you have to. The laptop should be able to see it now. (There is also a setting in the Windows wireless network properties that you can check to connect to a network even if it is not broadcasting, as long as you have connected to it previously.)
Hope that helps!
May 17, 2010 | Dell Latitude X1 Notebook
Have a Dell Latitude D600, the wireless stop locating wifi after a power outage, has an X on it. How do I get it working again?
you can try going to my network places and then clicking on view network connections on the left and if the connection is there right click on it and make sure it is enabled
Apr 20, 2010 | Dell Latitude D600 Notebook
Dell Latitude D600 - most all site certificates show invalid
This has to do with the security settings. Try adding the sites as trusted sites. You can also try lowering the security. It may be that the previous owner set the setting to high. Both setting are found under Tools\Internet Options\Security. You can also compare the settings from a machine that does not give the messages to the one that does and adjust them to get rid of the problem.
Good luck, and please let me know how it works out for you. ~ Spoem
Mar 23, 2009 | Dell Latitude D600 Notebook
Problem with network drivers
Click Here which will take you to the dell support and drivers page. Select the drivers you want and download them to a pen drive, and then install them to the D600. :)
Mar 14, 2009 | Dell Latitude D600 Notebook
Dell Latitude 60 Laptop Won't Load windows
You can either press F8 repeatedly at boot or the Delete key for setup to change the boot drive to cd with the Windows cd. F12 will get you a one time boot option as well. Steve
Jan 26, 2009 | Dell Latitude D600 Notebook
Dell D600 wifi
Do the Basics First;
  1. Make sure you turn it on or switch it on
  2. Reboot your PC
  3. Make sure your router is set to broadcast your SSID
  4. Right click your wireless connection and select "repair"
If still doesnt work;
  1. Select and double click your wireless connection
  2. Click on properties
  3. In the middle of the box find, select and highlight Internet Protocol (TCP/IP)
  4. Click on Properties
  5. Make sure "Obtain IP address automatically" and "Obtain DNS server address automatically" are the only ones selected
  6. Click on the "Wireless Network" tab
  7. On "Preferred networks" make sure your wireless is there ( your SSID) if not Add it, move it up or remove the others
  8. Once its added highlight it and click the "Advanced" button and make sure to select "Access point (infrastructure) networks only
  9. Make sure this is NOT checked "Automatically connect to non-preferred networks" then click "Close"
  10. Highlight again and this time click "Properties"button
  11. Check "Connect even if this network is not broadcasting"
  12. Check authentication configuration
Jan 18, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
107 people viewed this question
Alun Cox
