Question about Pioneer Car Audio & Video
Pioneer deh 150mp will not power up after installation
informatica
  • 1114 Answers
SOURCE: Installing a Pioneer DEH-P77DH
You can download the manual from the link below: http://files-upload.com/files/461301/DEH-P77DH_install.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 26, 2007
SOURCE: Red wire Pioneer MP 2050?
thats funny
Posted on Jul 10, 2008
SOURCE: Pioneer deh 2300
if you were in augusta,ga i would give you one.i have a lot of them.... pioneer is the only cd player
i use
Posted on Sep 25, 2008
etirbynnor
  • 655 Answers
SOURCE: Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Posted on Jul 09, 2009
  • 3 Answers
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
Posted on Aug 12, 2009
Need wiring diagram for a pioneer DEH-150MP TO A 97 HONDA SW
Request the wiring diagram directly from Pioneer.
Jun 01, 2017 | Pioneer Car Audio & Video
Where does the blue wire that says system remote control go to..
You can leave it as it is (not connected), unless you're installing an amplifier to the system, if thats the case this is the amplifier signal to turn on.
Sep 22, 2014 | Pioneer DEH-150MP Single DIN Car Stereo...
Seems the heat sink runs about 150 degrees is this normal
Bad earth can cause it to run hotter than normal but pioneer do run very hot i have burnt my hand on them.
Aug 31, 2014 | Pioneer DEH-150MP Single DIN Car Stereo...
Cd not ejecting
Insertion of the wrong type of CD (as specifically identified in the instructions for the car stereo) could have jammed the eject mechanism.
May 14, 2014 | Pioneer DEH-150MP Single DIN Car Stereo...
Pioneer deh-150mp randomly turns off while driving
The ground connection from the amp to the chassis is probably loose
May 07, 2014 | Pioneer DEH-150MP Single DIN Car Stereo...
Do you have it in Demo Mode? Check out this video for details on how to get out of Demo Mode:
https://www.youtube.com/watch?v=cKk4CHawnZY
I want to hook pioneed dec150mp to a car battery to use at my house.when I did the power stays on constant
The yellow maintains memory and display if it has a clock, So that might be what you are seeing.
Feb 22, 2014 | Pioneer DEH-150MP
Car Audio & Video Logo
118 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
