Question about Nordic Track NordicTrack Treadmill, A2550
Treadmill belt keeps sliding to the left
Ok i bought I used treadmill from a family member and I see the belt had pulled way to the left..Welli got home ajusted and tighten it up and ran on it for about 30 minutes and right back to the left it was again..I centered it a couple times and after about 30 minutes it pulls back to the left.I removed the cover over the motor and everything looks pretty good besides some belt dust but not a lot..Now there is a screeching sound that sounds like its coming from the top roller and the roller looks like it is kinda wobbly a bit when you close one eye and look real good at the edge of the roller..Also you kinda feel a little viberation sometimes like maybe a bad burn or someting..Any ideal what may be my problem ?? The name on the machine says Pro-form 485 PI
  • 103 Answers
SOURCE: When I get on my treadmill it feels like Im
On the side of the treadmill where the tread is running into the foot rail (plastic). go to the rear of the machine and find the hole in the end of the plastic. There will be an allen wrench hole there. Use an allen wrench (should have come with the machine) and tighten this bolt (clockwise) 2 full revolutions. This should move the belt away from the plastic and possibly keep the belt from slipping. Good Luck, Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a proform 650 treadmill. It is working ..but strange sound
The front bearings have failed and is causing the hammering noise will need to replace roller. Go to iconfitness.com go to customer service then replacement parts you will find your M# and pricing
  • 1111 Answers
SOURCE: The belt of my treadmill
Hi stewarvm,
you either have a loose belt or possibly a bad bearing.
grab each roller (front and back of treadmill) and try and shake it up and down and front to back to
to make sure the bearings are ok...if they move a lot, then you probably have a bad bearing...if theres no movement, or very litte, they should be ok
now make sure the belts ok by looking at it and determining if one side is looser then the other (the right side should appear or feel looser) then tighten the right adjusting bolt till the belt tracks in the center. the adjuster is at the rear, one on each side of the rear roller.
HERE is a video and instructions of how to track your belt.
its pretty easy to fix and should only take a few minutes to get it right with a little trial an error if you never did it before.
let me know if you need further help.
Bill
Standing Member of G.O.T.
Posted on Nov 15, 2010
  • 95 Answers
SOURCE: Nordictrack C2050, belt was slipping and I got the
I am not an expert on what you may need to order but I do want to give you a link in case that may be helpful... FitnessRepairParts.com has parts lists for several versions of the C2050... look for a decal or label on the machine to get the exact model number, then click on that model and look in the list for 'Roller, Front' or 'Roller, Rear' or 'Treadbelt.' Hope that helps.
Also if you need someone to come look at it you can find a list of servicers near you here
Posted on Feb 17, 2011
How do I lubricate the walking belt ?
Video about How to Lubricate a Treadmill using Liquid Lube
  • This video will demonstrate how to properly lubricate your treadmill belt and deck. This demonstration is for the application of liquid lube.
  • To begin, clean the deck and belt by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt is loose you can take an old towel and place it under the belt as shown in the video. Move the towel up and down the deck, then using your hands pull the belt around half way to ensure you have completely cleaned the back of the belt. Then remove the towel.
  • Open your lube packet and use half of the package to make a half circle on the deck, from the front outer portion of the deck toward the center and then back to the outer edge. Use about half the package for this arc. Now repeat the process on the opposite side. Be sure to wipe up any excess oil as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the lubricant out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously.
  • Power on and start the machine; let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to lubricate a treadmill using the liquid lube.
How to Lubricate Treadmill Using Liquid Lube Video Video about How to Wax a Treadmill Using Powder Wax
  • Our video demonstrates how to properly wax your treadmill belt and deck. This video will be about applying the powder wax.
  • To properly lubricate or wax your belt and deck you will first need to clean between the deck and belt to remove any contaminants.
  • To do so, begin by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt and deck has been cleaned; Open your wax bag and using approximately a teaspoon, place the wax on the deck as seen in the video. Now repeat the process on the opposite side. Be sure to wipe up any excess wax as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the wax out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously. Remember to tighten only half way on each side then repeat the process.
  • Power on and start the machine and let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to wax a treadmill using the powder wax.
How to Wax Treadmill Using Powder Wax Video
Dec 07, 2014 | Exercise & Fitness
Belt starting slipping, adjusted according to User's manual...belt still slips.
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt.
If then also the belt is slipping then you have to replace the running belt with a new one.
ok
Sep 03, 2011 | Reebok T 1280 Treadmill
My belt keep slipping. And I try tighten the ajustment bolts.
Make sure you adjust vthe motor belt first, it may be where the slipping is coming from. You should only be able to twist a properly tightened motor belt 45 degrees. After that, readjust the walk belt. If you have been tightening the walk belt trying to get the slipping out it may be too tight now. Use the instructions in your owners manual to adjust the walk belt. Also, lube under walk belt with the recommended lubrication . That will help the walk belt not too grab and take pressue off of both belts. Good luck
Mar 15, 2011 | Horizon Exercise & Fitness
I have recently bought a second hand vivotion treadmill which is in excellent condition,but we have no manual,and since my husband fell off and managed to make the belt go to the left and rub on side which...
to get the belt back to the rite. first loosen the the right side and then tighten the left. so if you did 2or 3 turns on the right side then you do the same on the left. you want equal tension on both sides. this is what keeps the belt centered. the bolts that tighten the belt should have a washer in front of it there are two kinds of washers . flat and star I recommend star more gripping power
Mar 09, 2011 | Exercise & Fitness
The belt always moves to the right side
your roller ajustments are loose, loosing all the rollers front and back, re aline belt to center, tighten front roller first then tighten rear roller, Rear roller has 2 seperate ajusting allen bolts, 1 on each side, count the turns on each bolt when turning them inward, keep the count even turns on both allen bolts
Oct 24, 2010 | Proform CrossTrainer Treadmill
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
My freemotion treadmill is slipping, what can I do?
ajusting the belt tension rollers, front and rear rollers tighten with usually a allen bolt ajustment tool
Oct 24, 2010 | FreeMotion Treadmill t7.3
I was told too loosen the belt with the ajusting screws at the end of the belt when lubricating. now the belt wont stay in line it was perfect before now it goes off to one side or the other. what do i do
the adjusting screws are the answer.tighten the side where the belt goes .or loosen the other side. if you can do this with it running and it will correct the tracking as you tighten/loosen and you will know when to stop.
Nov 20, 2009 | Bowflex Treadmill Series 7
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
Nordic Track NordicTrack Treadmill, A2550 Logo
351 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
