Question about Kitchen Appliances - Others
Error code h01
First time I turn it on then closed the the door it ave me this code h01
4 Suggested Answers
Logjam
  • 159 Answers
SOURCE: Error code 061 and the ADF door is closed
In this case make sure that the plastic tab that actuates the sensor is not broken off. If it is, try and find some way to defeat it. Other wise you will have to replace the whole transmit door assembly.
Posted on May 27, 2008
ginko
  • 19396 Answers
SOURCE: H01 Error
H01 means that there is an alignment problem or there's a faulty lens mechanism. Align it would cost about $50 . If there is a faulty part , then cost would start from about $80 labour plus part.
Posted on Aug 08, 2009
Testimonial: "Thanks so much...repair is probably not worth the cost...."
sador77
SOURCE: Error code H01
it means no head motor rotation...The full meaning is given as: After Cylinder lock is detected the cylinder does not start rotating again even after tape unloading.
The remedy/ check is given as: Check the cylinder motor drive circuit... sorry no solution but at least you know whats wrong..
Posted on Aug 21, 2009
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Hoover washer dryer error code h01
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
Sep 12, 2012 | Hoover Washing Machines
Error code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Code 68 appearing on LCD screen off a brivis LPG ducted heater
This is a error that can be fixed with a specific reset sequence. Follow this process carefully. The unit will not turn on for long and turns itself off after about a second so you need to execute step 2 immediately after step one.
Step 1 - Turn on heater
Step 2 immediately press no 1 on the keypad - this will display the error code H01 #68
Step 3 Hold down no 4 for approx 5 secs till the screen goes blank
Step 4 The screen displays all of the settings and resets
Note: you may need to do this a few times before it works - wait some time before retrying. If a reset will fix the problem this is the solution - if it is hardware a service call is required.
Jul 18, 2011 | Heating & Cooling
Yamaha dvd s-80 showing error code H01 when trying to play disc. What does this mean ?
The manual isn't much help, is it?
http://www.retrevo.com/support/Yamaha-DVD-S80-DVD-Players-manual/id/320ag210/t/2/
It seems the "H01" is some kind of common and fatal error code in many disc players and I have yet to find anyone who has paid the ransom, er cost, to get one fixed as it is cheaper and makes more economical sense to just buy a new unit...
http://www.electronicspoint.com/panasonic-sc-ht75-dvd-player-broken-t55762.html
Feb 11, 2011 | Yamaha DVX-S80 System
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
H01 Error
Aug 08, 2009 | Panasonic DVD-RV32 DVD Player
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code H01
Aug 07, 2008 | Panasonic NV-HD680 VCR
Error code H01
I opened up by Panasonic dvd-cv52, which I purchased in Dec 2002 for H07.
The H07, based on research, indicated that the spindle motor had an issue, a post I found suggested trying some 3-in-1 oil.
I tried this and it worked (note, pop the top off firstm then power up the unit, then press the open button, then unplug the power, this will make it easier to lubricate).
Once I had done this and powere back up, I got h01.
Turns out I neglected to put back the elastic that is used to spin the carosel for the dvd's (I have a multi dvd player).
I would check to see if there is an elastic in place to spin the carosel, maybe your broke (assuming you have a multi carosel also)
Good Luck
Louie Whote
Oct 27, 2007 | Panasonic DVD-CV52 DVD Player
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
