Question about Video Game Consoles & Games
Green flashing light on davey rainbank controller
2 Suggested Answers
  • 42623 Answers
SOURCE: How do I check if a current overflow' problem is due to the Sensor or the Rainbank?
take the sensor above water level--say in a bucket of water then lift it out of the bucket
if the mains water flows or stops flowing depending on whether the sensor is in or out of the water will indicate it sensor or solenoid of the rainbank
I suspect that the sensor will be a simple float arrangement filled with mercury so that when it is hanging down ( no tank water) the mercury bridges a set of contact points and makes a circuit and when it get to a fill point the mercury flows away from the points and so breaks the circuit
Posted on Sep 28, 2016
Testimonial: "I should have mentioned that the Sensor is not a float but is actually fitted at several rungs above bottom level. I imagine thAt I should be able to measure a Voltage or ???? which is then connected to the Rainbank to switch On / Off the town water."
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
My rain bank davey pump is flashing a yellow light
if not running , check for water supply to pump or air in pump
prime and restart
Jan 29, 2017 | Cars & Trucks
Sep 28, 2016 | Washing Machines
What is a flashing green light on the dash board under the mph area.
Not sure which light you are referring to but the Traction Control light is in the same area and comes on for a few seconds when you start the car. To see if this is it hit the traction control button by your console and the light should come on
Aug 12, 2014 | 2013 Chevrolet Equinox
Davey HP45-05 with Rainbank will not turn off?
Hi Sam,
Combined Electrical in Fyshwick ACT here. Has your problem been resolved?
We have found that a leaking cistern which can only be a few litres a minute can cause this problem.
Aug 14, 2012 | Plumbing
Davey rainbank mk11 green flashing indicator .what does it mean?
We are having this same problem & we have lost water pressure. We were never given the manual to this system and can not find the solution on the internet. Did you find the soltuion?
Jul 28, 2012 | Computers & Internet
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
Lost Dynamic Falcon Mini Copter Manual/Instruction. What Does Flashing means while charging and why the green light isn't on?
The flashing red light means the batteries are low. The green light goes off when it's finished charging, or when there's not enough battery left to charge it.
Dec 21, 2010 | Atlus Video Game Consoles & Games
Green light flashes 9 times will not go
Hi. Different brands of controllers give different fault codes.If this is a dynamic controller, 9 flashes is the code for a faulty controller. This does not always mean that the controller is actually at fault.
It could be a burn't out brake solenoid, that now has a different resistance through the solenoid coil.
You mention the middle speed green light is flashing, normally on dynamic controllers, it is the most left battery level LED that flashes. You might have a different controller.
Have a look under the panels and let us know what controller your machine has.
You could try the agents, and see if they can tell you what the problem is.
Good luck. Neil.
Jun 06, 2010 | Golden Technologies Companion II Travel...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
