Need a driver. Using Vista-Ultimate OS. 32-bit.
I have this drawing tablet I had to use with my old system which had xp-os. My computer recognizes the product, but I want to install all the bells and whistles. You know the hot keys N all.
When I try to install from the disc, says cannot find the setup info. Tried start, F:run and f:setup. Also explored the cd, and hit the setup icons. says cannot find the setup folder.
Can you help me buddy.
Steve from New Orleans.
  • Jay
    Jay May 11, 2010
    It's probably software issues with Windows Vista, why don't you try the manufacturer's website and see if there are drivers compatible to Windows Vista.
First start your window and put cd on your pc then restart now its time press F12 then set CD-ROM press enter then automatic its said set up your cd icon what ever.
Posted on Apr 17, 2009
Why is the screen rotation is not working on hp touchsmart tx2 tablet?
what is a tx2, circa 2007 device?
its a very old laptop.
right> super old running XP, right? is it/? or Vista 32?
HP TouchSmart tx2 Notebook PC
no OS stated, what operating system is running,??????
has the OS been upgraded, or changed? we cant guess that.
The Drivers on this touch pad are failing.
if you go to HP.com you can get the correct drivers.
but they will ask you for the full model number not just terse tx2
see them here.
https://support.hp.com/us-en/products/laptops/touchsmart-notebooks
there are 4 , classes of TX2
failures like this are software or hardware caused.
if software can be virus infected, that both vista and Xp worse
will be... and endless. pain there.
or someone loaded wrong OS, or wrong drivers.
all that is called OS corrupted, in one form are another.
Id reload the OS using real HP disks.
or try the drivers seen here.
i guessed VISTA 32, if not vista 32, tell HP what it is now.
https://support.hp.com/us-en/drivers/selfservice/hp-touchsmart-tx2-1000-notebook-pc-series/3837256
Jun 22, 2017 | HP Computers & Internet
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
Hi...I just formatted my x61 tablet with windows XP pro...But I cannot get any of the tablet features and touchscreen to work...I have all the updates and lenovo toolbox say everything is installed...did i...
Maybe IBM have some drivers but as XP is obsolete, they may not.
Operating Systems as supplied from new.
Microsoft Windows Vista Home Premium 32-bit
Microsoft Windows Vista Business 32-bit and 64-bit
Microsoft Windows Vista Ultimate 32-bit
Microsoft Windows XP Tablet Edition 2005
Are you using XP Tablet Edition as that edition has the drivers for the features?
Feb 15, 2011 | IBM ThinkPad X61 Tablet PC
I have a CanoScan LiDE80 that wont work now with my new operating system, Windows 7...when trying to install it.. says I need drivers but can't find compatiable one??? Any suggestions as I love this...
Do you have Win7 32-bit or 64-bit? If you have the 32-bit, the driver you need is here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . This driver works for Win2K-Win7. This is an unsigned driver and probably will not work in Win7 64-bit.
In my experience, Canon is very poor at supporting their scanners for 64-bit OS versions. In fact, they do not have a Vista 64-bit compatible version of the drivers for this scanner.
The only solutions I have found are tedious. 1) Keep your old computer that works with the scanner and transfer files on a USB drive or optical disc (RW is better for this). 2) Set up a virtual computer with an OS that works with the scanner. If you have Win7 Pro or Ultimate, you can do this for free. Download Microsoft's Virtual PC and the XP mode package. Install both in order. For other versions of Win7, you will need a virtualization program (Parallels, Virtual PC, VMWare) and a licensed version of XP (or other OS that will work with the scanner). Set up the virtual computer program and install the OS.
Next install your scanner to the virtual computer and use it in that "machine". You may need to transfer files to external or optical media to share the documents. You can't install a printer on both the virtual computer and the real computer at the same time (at least with XP mode).
I hope this helps.
(I tried using the compatibility mode and accepting the unsigned driver for a Win7 Home Premium 64-bit machine for a different Canon scanner. It didn't work and I have dealt with a number of old hardware and new OS issues over time.)
Dec 01, 2010 | Computers & Internet
My cannon canoscan lide 20 lide 30 driver,dose not install with windows 7
Do you have the 32-bit OS or the 64-bit OS? The Canon drivers will work in 32-bit Win7. However, Canon doesn't support these scanners in the 64-bit OS. The only way to make the scanner work in the 64-bit OS is to run either a dual boot system or a virtual computer with a supported OS. The Vista x64 bit driver doesn't work even if you use the compatibility mode.
If you have Win7 Ultimate, you can download Microsoft's Virtual PC and the XP mode for free. All other virtualization software options (Virtual PC, Parallels, VMWare) require a paid (licensed) version of the OS. Then install the scanner in the virtual computer and transfer files to external media to share it with the main computer. Dual boot systems have the same restriction of needing a valid OS.
I'm not aware of any Canon drivers for this scanner under UNIX.
I wish that I could be of more help.
Sep 02, 2010 | Computers & Internet
I have a dell 946 all in one printer... everything works but the scanner... I just purchased a new computer that has vista and my old computer had xp... worked fine on old puter... any suggestions
You need a new driver from Dell that funtions with Vista. If you have Vista X64 OS then this function may not be available for a while longer as the driver for the scanner is still in development. There is a significant difference between a 32-bit and 64-bit OS.
I'm running into networking problems with my Vista X64 OS and a printer on my home network that connects through XP Pro on a desktop computer with a 32-bit OS.
A Windoze Vista 32-bit laptop has no problems with this printer.
Sep 04, 2009 | Dell 946 All-In-One InkJet Printer
Drivers for M5641
There is no difference whatsoever between drivers for Vista Home, Vista Ultimate or, indeed, any version of Vista. They are all the same Operating System just with bits enabled or disabled accordingly.
Please can you clarify exactly which OS you have. Is it 32 bit or 64 bit? You will almost certainly have the 32-bit version and need to go to the appropriate page. 64-bit drivers will not work with 32-bit Os's and vice versa.
Just in case, here is the link for the drivers... yoiu just need to choose the exact OS remembering the 32 bit option (assuming you do have a 32-bit OS)
http://www.acer.co.uk/acer/service.do;jsessionid=D4148C2C74F2951FDADA15EDEA7EC063.public_a_14c?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1.att21k=1&CRC=3713735360
Aug 24, 2009 | Acer Aspire RC500 PC Desktop
I need dirver Windows Vista 64 bits for Handycam TRV-740
This was taken from Sony's Website....
Driver information for Microsoft® Windows Vista® and Windows® XP
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
  • The USB streaming feature is not supported with the Windows Vista operating system.
  • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
  • The Windows Vista Starter edition and Windows XP 64-bit operating systems are not supported.
So as you can see...the 64 bit OS is NOT supported.  The only luck you are going to have is either go to XP, Vista 32 bit...or see if there is a 3rd party driver someone made on the internet.  Try google....but I would have to say due to the complex nature of the drivers, it is highly unlikely that anyone has made a driver that is compatible.  It just has to do with how the 64 bit OS is made.  There might be a way to use 32 bit drivers, however you might run into some issues with processing and streaming.  To my knowledge of 64 bit systems, they are backwards compatible with 32 bit applications, so you can use wither 32 or 64 bit drivers....the only downside is by using 32 bit on a 64 bit machine, you are going to suffer a little bit of performance loss.  I hope this answers your questions.
Feb 22, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Computers & Internet Logo
David Payne
David Payne
