Question about HP Compaq Presario v3000z Notebook
I got presario v3000 notebook,it hangs up after win-xp logo & if we run it in BIOS setup we are getting horizontal lines on whole screen
  • 520 Answers
Your vga is on its way out (graphics card) or you have incompatable display drivers.
replace card or try install correct drivers.
check device manager for any faults with drivers(in safe mode )
Posted on Jan 28, 2009
    Genius:
  • HP Master
  • 1,102 Answers
Try a virus scan
then a disk defrag
are you getting any errors
Posted on Jan 24, 2009
My laptop not getting started and if i try to boot from windows setup its getting hanged
Try running the Check Disk Utility. Hopefully your operating system is still there to run the check disk utility. I do see where you say you ran a format which might have wiped it out.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 04, 2012 | HP Compaq Presario V3000T Notebook
Compaq v3000 cant play dvd after re install win xp
Try to upgrade your media player or install third party player available on the net which can play dvd.
Apr 09, 2010 | HP Compaq Presario V3000T Notebook
Bios chip location on mother board
no,, reinstalll the vista,, the problem will not occur again
Jan 08, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V4215EA won't boot, switches off by self
sorry dude, this seems like a prone problem on your own PC, this is what you do lete a PC engineer check it out. or if it is still on waranty return it. good luck
Aug 28, 2009 | Compaq Presario V4000 Notebook
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
My laptop v3000 always hang and then blank
Read this article and see if it applies to you. There's a special phone number for HP in the article. If this is your problem, you might be able to get a free repair. Good luck.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Jan 25, 2009 | HP Compaq Presario v3000z Notebook
Audio drivers
I already inatall sound driver in my HCL laptop from supplied driver CD. But sound is not playing.
Sep 07, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
HP Compaq Presario v3000z Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
