How to reset Sharp EL 533x? - Office Equipment & Supplies
How do you reset sharp EL-531XH calculator
There's a small hole in the back marked "RESET." Poke a straightened paper clip or similar implement into the hole.
Aug 04, 2013 | Sharp El-531x Scientific Calculator Green...
How do you reset the Sharp EL-2630P III Calculator without switching it off or using the reset button at the base of the calculator?
Look for a CE key to ( Clear Entry) or AC key to Clear All.If you have Memories, store 0 values in them. That is the most you can do to Reset without Resetting. Pardon the oxymoron.
Jun 28, 2011 | Sharp EL-2630P Calculator
How to set date and time on sharp el-1801pIII
User guide is here ...
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-1801PIII-_E
Instructions are halfway down column 1.
Basically, you use the reset button on the back, then enter the relevant fields, delimiting as with a period <.>
I think their illustration explains it better than I can in words!
Feb 28, 2010 | Sharp EL-1801P Calculator
I have a Sharp EL-531W.All keys work except for sin cos tan hyp.
No solution, but I have the exact same problem with a Sharp EL-531W calculator. Doesn't matter whether mode is degrees, radians, etc., and resetting with button in back has no effect.
Feb 26, 2010 | Sharp EL-501WBBL Calculator
Sharp EL 531w . the calculator doesn't turn on.
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
Apr 15, 2009 | Sharp EL-531VB Calculator
Sharp EL-1801V Calculator
Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
Apr 02, 2008 | Sharp EL-2630P Calculator
Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Mar 26, 2008 | Sharp EL-2630P Calculator
Sharp el-1197p3
push and release reset button many time while you apply dry contact cleaner on the button- remove the power and return it twice.
Feb 12, 2008 | Sharp EL-1197P Calculator
148 people viewed this question
jasbo
jasbo
