Error message code E_AUTH_BAD_DEVICE_KEY - Computers & Internet
I need to Get the authorization code for this software that my wife got for me in 2002? It's autocad LT 2002 serial #341-88732540. Key#HQZ3U6. Any help would be appreciated. I've tried registering it...
Autodesk AutoCad 2000 serial: 112-11111111
cdkey: 5X8NUG
Autodesk AutoCad 2000 Educational serial: 111-11111111
cdkey: GX8NUG
auth: FFD54A5A
Autodesk AutoCad 2002 Serial #: 400-12345678
cd-key : T4ED6P
Autodesk AutoCad Data Exchange 2000i 400-12345678
Autodesk AutoCAD Land Development Desktop Release 2i s/n: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2000 serial: 110-98539662
cdkey: 2ZC3DJ
Autodesk AutoCAD LT 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2002 s/n : 400-12345678
cd-key : T4ED6P
Autodesk AutoCAD Map 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2000 s/n: 110-98539662
cd-key: 2ZC3DJ
AuthCode: 08BB785
Autodesk CAD Overlay 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2002 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Civil Design Release 2i serial: 400-12345678
cd-key: T4ED6P
Auth : no requiere
Autodesk Civil Design 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Land Development Desktop Rel. 2 Serial #: 400-12345678
CD-KEY : T4ED6P
Auth : no requiere
Autodesk Land Desktop 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk LightScape name: EzD
company: PWA
s/n: 700-15158000
code: 6A147AF9
Jan 31, 2015 | Autodesk AutoCAD LT 2002...
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
May 19, 2014 | Toshiba Satellite A135 Notebook
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
Mar 15, 2011 | Computers & Internet
-ERR [AUTH] Error logging in. Please visit http://mail.yahoo.com hit wrong button when trying to log in and this message came up
Try reloading the page and make sure you are typing your password correctly. Also make sure the CAPS LOCK key if off.
Mar 06, 2011 | Yahoo Mail
CODE ERROR 10
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10)Recommended resolutions
Here are some things that you can try to resolve this problem.
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
Feb 26, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
CODE 10 ON TSST l632@ VISTA os
This is from Microsoft and is from their code explanation page.
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
Jan 15, 2010 | HP Pavilion DV6700T Notebook
What is error number 10
Hello there
I have sent you this list of codes and possible solutions for this ok?
best regards michael
Oct 14, 2009 | HP Computers & Internet
Panasonic dpc322 enter identification code
1. Function key
2. General Settings
3 key operator mode #9
4 Enter Keyoperator mode password protected
5. selected user authcentication Number (75)
6 select Copy/fax/print/scan
7 select on for auth or off no auth
Jul 20, 2009 | Panasonic Office Equipment & Supplies
M2N-MX sound
Try reinstalling the drivers, which can be found here.
Apr 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
