Question about EliteGroup P4VMM2 Motherboard
I have a board but i canm with nottin i put all my stuff in i got three beeps my friend told me to change a jumper no it 1 solode long 3 or 4 sec beep
  • 32 Answers
Check to make sure your RAM is securely fitted in the slot.
Posted on Jan 24, 2009
Motherboard goes for 3 seconds then shots itself
hi i like to help. first off, put back the old processor and reset the motherboard. you''ll find the jumper caps near the battery or you can read the label on the board something like jbat1. put the jumper cap on pins 2 and 3. wait 10 secs to reset the board then put it back to pins 1 and 2. The board should work now. to upgrade your processor i think you have to upgrade the bios first. download it from the manufacturers website. after bios update, replace the procesoor and it should work again.
Apr 17, 2012 | MSI K7T Pro2-A MS6330 (K7TTURBO-R)...
At startup I get 6 beeps. No video. hard drive had a virus on it. was working just find before the virus. ( clean the virus off). was also getting message " hit atny key to wake from sleep mode." not...
Do the beeps have a sequence? like 2 long, 2 short, 2 long. It is very helpful to know the beep code. Remove your video board ( if you have one ) and see if the same beeps occur. If not, put video back in very firmly and remove all memory chips. Same beep code? Put in one memory chip in the slot A1 conn.
Does this help you? If there is no change, jumper your rtc to wipe out battery. wait 30 sec. then put jumper bck to normal position. If you can, removing the nickel Battery would be a good idea for 30 sec. Make sure to put it back in. If you're still getting the same beep code, or if it has changed to a new tempo, we are on the right track and you will be able to fix it.
Mar 21, 2010 | Dell Dimension 4700 PC Desktop
LOOK HERE FIRST!!!same deal, went off one day to never reboot. bought a new motherboard after testing everything else and still no boot. STOP DOING THIS!!! I needed to test the ram first, by chance I put...
Remove your battery from the motherboard for 30 sec. Jumper rtc jumper to short. Replace battery after 30 sec. then put RTC jumper back in correct location ( 1-2 or 2-3 ). leave like this another 10 sec then boot again with both Ram sticks. Make sure they are identical.
Oct 11, 2009 | E-Machines eMachines Desktop PC
Son got into my bios and changed video setting from auto to int. Now I get a black screen, computer beeps like it's booting, I just cant see anything. Any ideas?
You need to reset your BIOS. To do this, you will need to open the side of your computer. Somewhere on the motherboard will be a jumper, possibly labeled clear cmos. There are three pins, usually with a cap on the first two. Remove the cap from 1-2 and put it on 2-3. Then, put it back again.
If you cannot find the jumper, then you can always remove the battery for a couple of hours. Put it back in again and your defaults will be loaded. You'll have to go in and set the time and stuff either way.
Jul 08, 2009 | Gateway Computers & Internet
CHANGED CPU SPEED ON MOTHER BOARD "FOXCONN 661M08-FX-6LS" AND NOW KEEPS BEEPING. CAN I RESET MOTHER BOARD. THANX
Yes you can reset it, just make sure you unplug the computer before doing it...
Open the left sidepanel and either look for the clear cmos jumper and switch it to the other pin for 10 secs, or you can remove the cmos battery for 10 secs
Sep 19, 2008 | Computers & Internet
Pc chips m811
try to reset the BIOS to default either take the M/board battery out for at least 1 hour reinsert battery and try or
On M/board will be writing with reset bios or similar usually a small 2 pin connector with a jumper on 1 pin connect jumper over both pins remove jumper refit over 1 pin and reboot
If 3 pin setup remove jumper and fit over middle pin and the one it was not on replace back to how it was and boot computer
Aug 04, 2008 | ASUS K8V-MX Motherboard
Reset bios password
just the jumper position on the mother board pin 1 and pin 2 will be occupied just unplug the power cord and remove the jumper and put the in 2 and 3 then wait for 5 sec then put the jumper to original position and power the laptop
Apr 26, 2008 | Acer TravelMate 2300 Notebook
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
EliteGroup P4VMM2 Motherboard Logo
32 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
