Question about Kenmore Dryers
Kenmore 110 646 dryer start click
Won't start
  • 385 Answers
SOURCE: Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
Posted on May 26, 2011
heatman101
  • 43501 Answers
SOURCE: My Kenmore dryer won't stay
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 02, 2011
Testimonial: "you have been alot of help now I need to go home and double check the items you have listed to see if I can get my dryer to work"
canwoodjc
  • 3301 Answers
SOURCE: My Kenmore 110.66962501 dryer doesn't start.
if your sure the thermal fuse is good,, check the start switch,, making sure the dryer select setting is set to something other than off, also, the door switch . you can Jumper both these switches, I'd try the door switch first as they go out more often . if you have a meter and want to test the switch Some door switches have only two metal prongs extending from the body, while others have three. Those with three terminals will have a common (COM) terminal, a normally closed (N.C.) terminal, and a normally open (N.O.) terminal. Those switches with only two terminals will have either a common terminal and a normally open terminal, or a common terminal and a normally closed terminal. We are providing directions for testing a door switch with three terminals. If you are dealing with a door switch that has only two terminals, ignore the part of this test that does not apply to you.Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch each tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
Posted on Jul 20, 2011
heatman101
  • 43501 Answers
SOURCE: My series 80 Kenmore dryer won't start
heatman101
Posted on Aug 05, 2011
heatman101
  • 43501 Answers
SOURCE: My Kenmore 600 series dryer
heatman101
'lll
Posted on Aug 18, 2011
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
I have a kenmore 90 series elec dryer. Model # 110.64924200. When I turn it on it won't start, however I can hear it click. Like a car turning over but won't fire. Any suggestions? Already cha
the start relay in the control panel is bad,the relays coil is moving this is the click you hear,but the main contacts in the relay are bad there are 4 wires to it 2 for the start switch and 2 for the main contacts
Oct 24, 2012 | Kenmore Dryers
Spin the drum by hand to see if you feel resistance. The belt may have broke.
Oct 21, 2012 | Kenmore Dryers
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
heatman101
Sep 19, 2011 | Kenmore Dryers
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
I have a Kenmore 85089 Electric Dryer HE-4, everything works except when I push down start for the dryer to start it clicks but won't start..
heatman101
Jun 13, 2011 | Kenmore Dryers
May 26, 2011 | Kenmore Dryers
Dryers Logo
22 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
