My lexmark X7500 scanner wont communicate with my dell inspiron
Ok - I just got a lexmark all in one printer/scanner/copy/fax wireless. I am not using the wireless I am using USB connection. Printer works fine, fax works fine BUT the scanner won't work. I have a Dell desktop Inspiron. I worked with a great tech from Lexmark for 2 hours today and he said it seems that this is a dell problem (and I actually believe the poor guy he did EVERYTHING possible from what I can tell) I mean - he spent 2 hours...anyway - anyone know what to do here? When I called Dell those nice guys (Gags and pukes) said they sure could help me ... to the tune of $70! or for free (my warranty) they could do a system restore (which my kid could do) Help! I love the printer and just can't afford anything else now (and of course my return time is over)
  • Anonymous Jan 24, 2009
    I hate to sound like an idiot...and I so appreciate the advice but how would I do this? remember now I am an old broad! LOL (hitting 50 here soon) - I surely appreciate the advice! I just know there is something to fix this and you know - NOW its almost like a quest so I get some ha-ha vengence on Dell! They can't trick me! (evil grin) thanks again pappal....
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
It can be the problem of sccanner cable to scanner card.try to change it.it is only fault more.
Posted on Jan 24, 2009
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Windows 7 64bit, home network. Lexmark interpret s405 all in one.Trying to scan with windows fax and scan. can printer with no problem. windows fax and scan cannot find scanner. I look in device manager...
Try to re-insert the installation disc that came with your printer. Run the disc and make sure to install the Lexmark scan driver. If you have a firewall enabled, make sure to allow all access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
May 11, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I just purchased your 705 professional series wireless printer. Can I use this with my non wireless computer laptop? thanks I have a Dell Inspiron computer.
Yes, the printer can still be connected to your computer via the USB cable. Before connecting the printer to your computer, I suggest you insert the installation cd in your computer first. Run the software and follow the instructions on it. While it is installing, the software will also show you a step-by-step instructions on how to setup the printer itself. Hope this helps.
Jul 13, 2010 | Lexmark Multifunction Wireless Printer/...
Printer works, scanner/copy does not
The problem could be because of ONE out of TWO problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 24, 2010 | Dell 924 All-in-One InkJet Printer
My Dell A810 won't scan. Prints ok, copies ok but won't scan. Have Vista home Premium and a new Dell Inspiron. have uninstalled and reinstalled the printer twice but still won't scan.
Can't remember, but I believe you should have a fault programme which can access to run a self check?
All in one means able to send a "Fax".
If I'm right you have two settings for faxing, either entering doc in to tray or placing on scanner to be copied then faxed.
If so and you are able to fax to anoth er fax number see if you can send fax via your scanner. I'm am trying to find out if your scanner then starts up, strode lights up and copies, least you know important bits are working.
If it does light up, chances are present prog is not vista compat. Go to www.hp.com enter your printer details search it will come up with latest updates and full progs, look for the vista prog. Good Luck.
Nov 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Its a lexmark x75 scanner/printer. I can't find any printer/scanner icon's. It was hooked up and working 6 month's before it was given to me. it's a flattop scanner & the paper loads in the back. I...
Make sure You have  driver for it. Drivers are available on numerous sites for it. Any USB connection on the system unit should work with the installation.
Jun 06, 2009 | Lexmark X7500 MFP Flatbed Scanner
Wireless lexmark not communicating
maybe its not compatible with your comp at happened to me
Dec 27, 2008 | Lexmark Multifunction Wireless Printer/...
Lexmark x75 printer scanner
I am not sure if you need the X75 or X7500 so here are both of them.
X75 download
X7500 download
Jan 18, 2008 | Lexmark X7500 MFP Flatbed Scanner
Lexmark X4270 won't install
if possible try a different wire or usb port
check if there is a usb conflict
just some thoughts,
good luck
Nov 12, 2007 | Lexmark X4270 All-In-One InkJet Printer
107 people viewed this question
jasbo
jasbo
