Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
Bios problem there is no display to the board but when i put a pci display card on it the display come showing that searching bios file on hard disk , that means the bios is damaged . i have down loaded the bios file but i dont know how to flash it.
    Scholar:
  • 88 Answers
Here a link from Gigabyte that will help you fix your corrupted Bios problems.
Gigabyte
I hope this helps, and thanks for using fixya,
Eric
Posted on Jan 24, 2009
  • Eric
    Eric Jan 25, 2009
    sometimes I wonder why I even bother to try and help people. You probably didn't even read through the link I have sent you, because it clearly explains how to fix your corrupted bios issues. I do appreciate the thoughtfulness you put into rating my effort to help you.
    Eric
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
Intel 845gvsr mother board display not comming,even bios settings also not showing
I would check that your monitor is working. Further, check that there is not a second video card in the system. That will override the card on this board. You could try the J-21 Jumper. This will reset firmware.
Another possibility is a failed BIOS update. If that is the case; and it sounds like it is, I would go to http://intel.com and download the "recovery bio" following the instructions. To put it on a CD or floppy disk. (You simply put the file on a disk) put it in the drive and wait. After awhile, if the bios is corrupt; it will update and you should be on the way to success. Hope that helps.
Jan 06, 2011 | Intel D845GVSR Motherboard
Does not boot
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
May 08, 2010 | ASUS P5RD1-VM Motherboard
Sata drive not recognized at boot up
I HAVE UPLOADED THE MANUAL HERE, IF YOU DON'T WANT TO WAIT THEN GET INTO YOUR BIOS BY DOING A HARD BOOT AND HITTING THE DELETE BUTTON ON START-UP.IF THE MOTHERBOARD SUPPORTS SATA , TO WHICH I FOUND NO CONFIRMATION , YOU CAN CHANGE IT BY GOING INTO THE ADVANCED SETUP PAGE AND CHANGE THE FIRST BOOT DEVICE TO SATA RATHER THAN IDE. YOU WILL ALSO WANT TO CHECK THE PCI SETTINGS AS WELL FOR YOUR CONTRLOLLER CARD ....GOOD LUCK
Jun 02, 2009 | PC Chips M825G Motherboard
To upgrade the bios of intel 845gvsr for sata port
I have intel 845 series mother board but i dont have the motherboard cd
Aug 19, 2008 | Intel D845GVSR Motherboard
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Mike
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
NVIDIA PCI Card Issue at system boot
re-seat the graphics card, check the temperature, if overclocked try to put it at stock or RMA the card might be faulty
Mar 17, 2008 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Intel Desktop Board D815EEA2
Leave the connection to graphics card in, and take the left side panel off the pc and on the motherboard, you will see either a terminal marked CLRCMOS,JBAT1, CLRRTC, RTC, this is the cmos clearing jumper to revert back to default and the need to reset the time and date. If it's JBAT1 3 pin terminal, the cap will need to be taken off pins 1-2 and put across pins 2-3 then back to pins 1-2. If it is one of the others and only a 2 pin terminal, use a jumper cap like the one on the back of your hard disk and cdrom drive and put it over the 2 pins. start up pc and you should get the screen a beep and it will say press f2 for cmos setup, correct the date and time and the bios should be reset to vga, so change to pci again.
Apr 18, 2007 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
140 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
