Question about Electrical Supplies
Avic 930bt dimmer lights - Electrical Supplies
I have replaced Decora dimmers with the Adorne dimmers not the lighting is emmiting a high frequency noise in the mid dimming range. The lighting is 20/35 watt halogen lamps. Why and how can I fix this?
They design dimmers for either incondescent lighting or fan motor controls. Always check which one you purchased. You can't use the motor control dimmer on lighting and vice versa. Even if you purchased the correct dimmer remember that it is for incondescent lighting only (ordinary light bulb). Incondescent lights have a resistance whereas fluorescent has a capacitance and an inductance. Halogen lamps may have a capacitance and an induction too and are creating havoc with the mosfet transistor inside the dimmer. This can also cause the dimmer to fail. Read the instructions on the dimmer to see what type of lighting is allowed.
Oct 25, 2013 | Legrand Adorne Control Box with Paddle...
My Lutron dimmer/lights suddenly will not turn on. all electricity works throughout the house. The green light that usually is lit on the panel is not on either. any suggestions?
Indicator light is OFF.
Either dimmer stopped working or power to dimmer is off.
Check if electricity is present inside box.
Check nearby electrical plug to see if everything nearby has power.
Swap dimmer with regular switch and see if lights turn ON.
Check dimmer wires: if wires to dimmer are pushed into 'quick connect' holes on back of dimmer, these wires can get loose.
If dimmer is connected by wire nut, sometimes a wire can pull loose.
If no electricity is inside the box, and breaker is ON, then there is a loose wire inside one of the boxes on that circuit and electrician has to track back until loose wire is discovered.
Replacement parts for in-wall devices are not made.
If new dimmer is necessary, consider lighting factors:
Total wattage of lights. New dimmer has watt rating.
Type of lights. Dimmers specify florescent or tungsten (incandescent) or both.
Single-pole and 3-way. If two dimmers control same lights, one is control dimmer, other is companion dimmer.
Nov 15, 2010 | Lutron #MA-LFQHW-WH 300W White SP Light...
I can not find out the color meanings. Power, ground and such please help!
Ok,
Power 12V + : Yellow
Ignition Switch : Red
Amp Turn on : Blue / White stripe
Antenna : Blue
Ground : Black
Illumination :Orange/White
Dimmer : Orange
Left Front Spk + : White
Left Front Spk - : White/Blk
Right Front Spk + : Gray
Right Front Spk - : Gray/Blk
Rear Left Spk + : Green
Rear Left Spk - : Green/Blk
Rear Right Spk + : Purple
Rear Right Spk - : Purple/Blk
Hope this is helped you,
Good luck.
May 21, 2010 | Pioneer AVIC-N1 Car DVD Player
My avic x1 have no screen light buttons donts work apart from the eject button tryd new ribbon any other ideas please
i am having the same problem.... the only button working is the eject button, theres no sound and no screen display although the facia lights are on.. help!!!
Feb 20, 2010 | Pioneer GPS AVIC-X1 car radio
My pioneer avic n2 will not turn on,but when the
sounds like you have blown your acc fuse or your risistor on your red wire on your radio has shorted out you can bypass this wire by choping it off it dose not affect the radio ,dvd at all.
Jan 17, 2010 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-N3 no LCD sub panel light, also can't get the DVD out.
We can fix this along with all over AVIC N1 N2 N3 problems. Check out or affordable repair service at www.turbotunes.com. We're ebay powersellers as well.
-Steve
Oct 25, 2008 | Pioneer AVIC-N3 GPS Receiver
Avic-n1
same problem n1/n3 avic series
Aug 11, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic-n2
davetuttle- is there a wire on this unit for the E brake,if so this wire needs to see ground in order to operate.Try this and it should get you running. cooltek Mar,3/08
Mar 04, 2008 | Pioneer AVIC-N2 Car DVD Player
My AVIC-N2 will turn on but nothing will happen?
hi
sounds like the flexi cable is faulty
part you need is gxx1257
www.carradiospares.co.uk
its not to hard to change as long as you take your time .
Mark
www.blueice-electronics.co.uk
Aug 13, 2007 | Pioneer AVIC-N2 DVD Navi Rcvr with 6.5"...
Electrical Supplies Logo
32 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
