Question about Viking DTWL4848 Kitchen Hood
How to take out the circuit board on a Viking DTWL 4848
I have a Viking range hood model DTWL 4848 that the fan will only run at high speed. I need to remove and replace the circuit board, but cannot find details to do this anywhere on line. The installation manual does not explain how the hood comes apart. I can get to the 2 side screws that support the large stainless steel panel that holds the electronics, but cannot get to the 3 screws that are inside. Any help would be appreciated. Thanks. Walt
  • wtalamonti Feb 02, 2009
    This range hood has the 1200 cfm external blower, so there is only the circuit board and halogen lights in the hood. I need to know how to get at the electronics. I installed the hood a couple of years ago according to the installation manual, but nowhere in the manual does it explain how to service any of the electronics.
  • Viking Master
  • 19,396 Answers
Try clicking here and entering model number here, this website offers schematics for most models.
If you cannot find the model number see finding the model number on your appliance.
Posted on Feb 02, 2009
  • 10,515 Answers
If you are not a trained professional, i would advise you to purchase new board rather than trying to rectify that. You might cause more more damage to it while repairing the board.If you need some websites where you can purchase circuit board, than let me know.
Take care and Thanks for using Fixya.
    President:
  • 2,559 Answers
Try this,look up inside behind the control board where the area is boxed off,this should be pushed towards the back for removal and access to the rear of the control board.I have also included a link to the service manual.
http://www.specsserver.com/CACHE/FILE8093.PDF
Posted on Jan 24, 2009
    Genius:
  • 1,665 Answers
Hi! You may try this link to ask a service manual or information about your model specs.
http://kitchen.manualsonline.com/manuals/mfg/viking/dtwl4848.html
  • 679 Answers
i'll find a service manual for you please go to the link>>
http://www.bellanca.us/Bellanca_Viking_Service_Manual.pdf
please let me know is it works or not, for further assistance.
Thanks
    President:
  • 1,952 Answers
Any fault with this unit should only be attend to by qualify tecnician
  • 4 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 24, 2009
    image.rangehoodsmall.com/images/products_info/kitchen/RA-30and31Series.pdf
    down load this page
    . Use this unit only in the manner intended by the manufacturer.
    if you have Questions. contact the manufacturer.
    After turning off the proper 120 volt circuit at the service entrance.
    drill out the electrical power line access hole marked on the cabinet
    bottom or wall. Use a 1
    v..
    "wood bit. To operate the electric drill. use
    an extension cord connected to another circuit.
    derkochline.com/downloads/installation-and-use-manual.doc
    mohammed marika thambi Feb 02, 2009
    www.hadco.net/documents/viking_designer.pdf
    DOWNLOAD THIS PAGE
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
What controls the speed of a range hood fan? , only when i push the hi button or the low speed button, the hi speed button only works. its a old model built in 1960 , can't find the model number ...
You will need to check inside the button contacts to identify if the control of current is by a series resistor or by the coil winding.
Since the high speed is working it is possible that the series resistor coil is open.So check for loss of contact continuity in the switch, if not you can use the present model of electronic fan controllers to give you a variable fan control. This can be connected to the main hi speed connection.
Tip: Identify the wattage and buy the regulator according to the specs.(42 inch type)
Dec 18, 2010 | Kitchen Ranges
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
BABT83.2AL Canopy Rangehood The fan/suction is not working. A slight straining noise is heard. The light is working as is the display panel.
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Apr 07, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Viking DTWL4848 Kitchen Hood Logo
52 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
