Question about Exercise & Fitness
I have a bladez elliptical and screen shows an error 1 code.. What does that mean ?
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: error code 1 on schwinn elliptical 420
Dear Sir:
adjust the speed sensor see the diagram attached.
2) the main board can be faulty.
3) Run the software calibration.
5_3_2012_12_02_47_am.gif sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: bladez elliptical
see the steps and fix it. God bless you
Adjust the magnet with bolt attached there are loose, tight very well and ready the resistance is the main parts that need repair,
However if the resistance is faulty, you must test again the magnet from the refrigerator by attracting or repeled, if do not pass this test replace it buying small cheaping from home depot or similar.
GoD BLess you
  • 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • Sponsored Links
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Read more: How to Fix an Elliptical Machine ' eHow.com http://www.ehow.com/how_4681374_fix-elliptical-machine.html#ixzz2DLrv9YSH
  • Sponsored Links
    Posted on Nov 26, 2012
    ercupa190
    • 12223 Answers
    SOURCE: F6 CODE ON A BLADEZ TREADMILL
    please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.ipqidqpmpqaaaabjru5erkjggg==12_31_2012_3_35_30_pm.gif12_31_2012_3_36_25_pm.jpg
    Posted on Dec 31, 2012
    Testimonial: "WHERE DO I FIND YOUR PERSONAL TIPS FOR TESTING THE MOTOR,,,, THE DRIVE MOTOR WORKS FOR ABOUT 2 TO 3 SECONDS THEN SHUTSDOWN UNDER A E6 CODE, I SUSPECT THE ELEVATION MOTOR OR SETTINGS IS OFF"
    Error code message
    What Does Your Treadmill's Error Code Mean? - LifeSpan
    www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
    Free
    May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
    [PDF]ERROR CODES: ADDITIONAL ERROR CODES:
    www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
    ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
    [PDF]Error Code Troubleshooting Guide
    Jan 19, 2016 | Exercise & Fitness
    E7 Error Code on BladeZ Fitness Powermills Treadmill
    Hello, E7 error means:
    - Elevation Motor Elevation Motor out of
    Range
    Replace Elevation Motor
    - Display Doesn't Lit Up
    On/Off switch Check if unit is turned on
    Insufficient Power Source Plug unit in a dedicated
    120V, 20Amp Outlet
    Line Cord Damaged Replace Line Cord
    Fuse Check Fuse on MCB
    Here is website with users manual and troubleshooting>
    H http://www.treadmillfactory.ca/support/635-640.pdf
    May 19, 2014 | Bladez Exercise & Fitness
    Why is my Precor Efx 546i elliptical showing an error message?
    Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
    2. Bad lower PCA.
    3. Drive motor is shorted or de-magnetized causing a high power demand.
    Corrective Action
    1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
    2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
    3. Test unit with a known good drive motor. Replace drive motor if necessary.
    Precor Error Code 29
    Feb 11, 2014 | Exercise & Fitness
    Too difficult to use even on easiest setting
    ask your persona trainer what he recommend you, in base to your need physical.
    God bles you
    Jul 16, 2012 | Bladez Fitness X350P Homecrosstrainer
    Error 30 problem for 556 precor elliptical
    Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
    2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
    3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
    4. Upper and lower PCAs have mismatched software.
    5. Another component plugged onto the PCA is overloading the +5VDC power supply.
    6. Bad lower PCA.
    7. Bad upper PCA.
    Corrective Action
    1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
    2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
    3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
    4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
    5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
    6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
    7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
    Precor Error Code 30 31 32 33
    Mar 03, 2012 | Precor EFX 546i Elliptical Version 4
    Elevation is not going all the way down and up have 12 error messages error 40,42,44,45. what do these mean and waht do i do
    If I posted the definition of each of these error codes, it would be a ton of information to process. I am going to attach a link to my support center. You can just simply type each error code in the search box and get the meaning and possible solutions for each of these error codes.
    SPORTSMITH LLC
    Aug 05, 2011 | Precor EFX 546i Elliptical Version 4
    What does error code 30 mean on the Precor efx 576i?
    6. Bad lower PCA.
    7. Bad upper PCA.
    Corrective Action
    Jul 16, 2011 | Precor EFX 546i Elliptical Version 4
    Tunturi elliptical cross trainer error e-2
    Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
    Apr 02, 2010 | Exercise & Fitness
    Exercise & Fitness Logo
    Top Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
