Question about Sennheiser Audio Players & Recorders
I have Sennheiser TR110 wireless headphones. The green light on the sender doesn't light anymore I and only get static on the phones. Can this be fixed.
They are only about 2 years old. Recently plugged them into a new TV. Joan 1-14-13
5 Suggested Answers
cardmechanic
  • 9 Answers
SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Posted on Jan 15, 2009
  • 7 Answers
SOURCE: No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Posted on Apr 02, 2009
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Posted on Apr 24, 2009
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
After working correctly for months, my wireless headphone stopped transmitting anything -- not even static
It could be that the rechargeable battery has failed. Take the batteries out and then replace them. Perhaps this may help you:
http://en-au.sennheiser.com/global-downloads/file/958/RS170_US_INT.pdf
Go to this site and it will automatically download the PDF file to your computer. Takes about 3 minutes. Go to Start> Documents> Downloads to find the PDF file RS170_US_INT.
Feb 05, 2015 | Sennheiser Audio Players & Recorders
Work fine for about 5 minutes than change to static
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting and shouldn't just cut out to static.
Jun 25, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser headphone static
you might check to make sure that your gain isnt to high many times this can negatively effect your sound quality
Mar 25, 2013 | Sennheiser Audio Players & Recorders
Sennheiser 120 green light goes off
Can you remove the rechargible batteries ? To try and reset them ? Or maybe replace them ? It sounds like the batteries have gone bad and not charging
Nov 12, 2017 | Sennheiser HDR 120 Consumer Headphones
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
Jan 08, 2009 | Sennheiser RS 120 Consumer Headphones
Dec 16, 2008 | Sennheiser RS 120 Consumer Headphones
No sound, only static
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Oct 18, 2007 | Sennheiser HDR 120 Consumer Headphones
78 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
