Question about Dell OptiPlex GX270 PC Desktop
Invalid boot file ini fix dell opti plex 270
When I start up my computer I see that it says in the top left and corner invalid boot file ini . How do I fix this ? I don't have a CD
  • Official Brand Answer
  • 560 Answers
Bonvicin66,
Unfortunately, you are going to need to have a Windows Disk to run a Repair Install from the disk. If running a repair install does not resolve the boot.ini error you will need to format and reinstall Windows.
To get a Windows disk you can search the internet for a disk. If you are in the US you can try getting a disk from the link below.
Dell Backup Media Online Request Form
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jan 15, 2013
5 Suggested Answers
bigbiggs
  • 326 Answers
SOURCE: Error on windows load
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
Posted on May 11, 2008
  • 18 Answers
SOURCE: dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Posted on Oct 28, 2008
motaro
  • 449 Answers
SOURCE: dell opti plex 755 ..its a company's computer and
check if the keyboard and mouse are well plugged into the appropriate socket change the keyboard and mouse if necessary
Posted on Aug 19, 2009
ErusTownsend
  • 592 Answers
SOURCE: Boot.ini file problem
if you have another computer to use you can look for the Ultimate Boot CD and burn a copy then boot to that. this will help you recover your data. there are also boot edit tools on that cd and you may be able to edit your boot.ini to fix the issue.
the only other way is to get a windows cd and use advanced repair to fix and rebuild the bootcfg
Posted on Feb 12, 2010
Invalid boot.ini when starting PC
The boot file is misplaced in your PC. to solve the problem boot it from an OS installation disk. then when you get the phase of installing there will be an option called "repair your computer". click on it and follow the instructions..(takes under 5 minutes) also use startup check to remove common errors..i can give you an accurate description if you post the correct OS i can give more accurate steps.
Apr 05, 2014 | Microsoft XP Computers & Internet
My dell d410 has an error it cannot find the boot ini.file it says it is invalid how can i fix this?
Assuming you have the bios configured correctly to boot from your hard drive, and you already have Windows installed (I'm assuming XP for srguments sake) it sounds like the boot.ini file has become corrupted. This can be fixed by basically following these steps.
- Insert your Windows disk and when you are prompted, press R to enter the Windows Recovery Console.
- You'll then need to select one of your Windows installation (probably just one) and enter the Administrator's password or if there isn't one
- When you reach the command prompt, type bootcfg /rebuild and hit
Feb 09, 2011 | Dell Latitude D410 Notebook
When i start my conputer invalid boot.ini to C:/ducument apear before open.
When you start your computer it says invalid boot.ini and then freezes there? Or, your system is booting into windows; and your receiving another error ?
Sep 02, 2010 | Computers & Internet
Please reinstall windows os in your pc , but retaining all your files and setting while installing process goes on. You should select leave current files and setting in the installation process to retain your valuable files.
Feb 12, 2010 | Dell Inspiron 530 Desktop Computer
It keeps saying invalid boot,ini file booting from c:windows
get a boot manger as it is safe to edit in GUi mode than in text mode;and fix it
Nov 24, 2009 | ASUS Eee PC 900 Notebook
Problem starting my computer
sound like the internal bettery need to be replace.
do yo have dula boot machine? if not, then change the internal bettery.
Mar 17, 2009 | Microsoft Windows 98 for PC
BOOT.INI deleted. How to re-create this file?
type in run "cmd" then presss enter then type "bootcfg /?" it gives u some help .
Dec 28, 2008 | Microsoft Windows XP Professional for PC
[boot loader]
timeout=30
[operating systems]
May 10, 2008 | Dell Dimension 4600 PC Desktop
Laptop
You may want to try to reset the BIOS to DEFAULT setings.
If this does not work...Try this turn the pc on and then press F8 a few times to access controlled boot precedure. You will be given some options and you should select "Start Windows in Safe Mode" . Hopefully, you can boot and inspect you boot.ini file.
Hope this helps
Justin
May 06, 2008 | Compaq Evo N610C Notebook
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Dell OptiPlex GX270 PC Desktop Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
