Question about Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
Error c2255 Error message comes up after changing the imaging unit(s). We had to change 3 of them and now printer does not work. Seems to be small issue of gears locking or something but I can't work it out.
2 Suggested Answers
  • 158 Answers
SOURCE: My Bizhub C350 has locked due a imaging problem.
once the machine locks you out for a imaeg unit you are done until the unit is replaced or reset chip is installed but there is new firmware that can be installed in the machine that wil not stop the machine from usage was the image unit has reached end of life so the next time a service tech comes out tell them you want the new firmwareand set image unit life to suspend
Posted on Dec 06, 2009
Error code c2160
.. have u got a make & model ..of printer. Cheers..
I found this info cyan PC drum charge corona malfunction. REMEDY check the Imaging unit contact and correct or clean as necessary.2 check the HVI 3,CHANGE imaging unit.4.change HVI.5,CHANGE PWB-MC sounds like a big problem.good luck
May 21, 2016 | Office Equipment & Supplies
Reset xerox c2255 btr (r7) counter
Code is 954-821
To enter diags and reset hold down right arror then left arrow, release both together the press online within 3 secs.
goto preventative, then HFSI. dont change anything else in this area as you can toast the machine.
Feb 11, 2015 | Xerox Office Equipment & Supplies
Error c2652 in konica minolta c250
C - 2651 Cyan imaging unit EEPROM acces error
C - 2652 Magenta imaging unit EEPROM acces error
C - 2653 Yellow imaging unit EEPROM acces error
C - 2654 Black imaging unit EEPROM acces error.
Clean the connection between the imaging unit and the machine if dirty.Reinstall imaging unit or change imaging unit.
Try reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON the copier.
Keep pressed the Utility key when the Trouble resest message is displayed.
Release the Utility key and touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Apr 16, 2013 | Konica Minolta bizhub C250 All-In-One...
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
How do I fix error code C2255 on my Konica Minolta C351 bizhub??
C2255 is the code for Color Developer Unit motor's failure to turn. This is usually caused by at least one of the Color Imaging Unit's being locked up or very hard to turn. If you are trying to fix this yourself then I would pull the Imaging Units out one at a time and check them against each other to see if one turns harder than the others. Note that there are 2 things to turn on the Imaging Unit. The Drum and the Developer section.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Office Equipment & Supplies
Phaser 7760 Error message: "Imaging
The black image unit of your machine should be replaced soon. It is a maintenance item and is very easy to change. They cost about $350 new, but you can buy one much cheaper rebuilt. Here is a video I made to help explain what it is you need to change and how to do it. Good luck
Nov 16, 2010 | Xerox Phaser 7760/YDX Laser Printer
C350 bizhub image unit counter won't reset after changing
using a post:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
thanks for krishmaqvan
Dec 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
May 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Intermittent "Invalid Imaging Unit" messages
sounds like your printer engine is starting to take a long unhappy downturn..
Jun 16, 2008 | Samsung CLP-500 Laser Printer
Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
