Question about Xerox Workcentre 5330/p 5330 Mono Advanced Multifunction Copier/printer/scanner
Error code 561 - Xerox Workcentre 5330/p 5330 Mono Advanced Multifunction Copier/printer/scanner
How to calculate 7^35mod561 in calci fx-991ms?
I don't have that calculator handy, but I imagine the problem is that 7^35 is an awful big number and the calculator would put it in scientific notation. So can we rearrange the question so that we can do it on the calculator.
The 7 is already prime, so we can't do much with that.
However, we can divide up the 35 into its factors of 7 and 5.
Thus, 7^35 mod 561 = (7^5)^7 mod 561
This becomes 7^5 mod 561 ^ 7 mod 561
16807 mod 35 ^7 mod 561
538 ^ 7 mod 561
241
IIIIIIIIIiiiiiii
I chIIIIIIIIIGood luck.
Paul
Good lcuk.
May 24, 2016 | Office Equipment & Supplies
How to FIx Code SC 561
Defective thermopile. If replacing the fuser does not help it will need to be replaced.
Aug 10, 2014 | Ricoh Aficio Office Equipment & Supplies
D04-561 riso error code
It is not recognizing your ink cartridge. Try another tube of ink. Otherwise you may need to reprogram the drum.
PrntNow.com
Apr 19, 2013 | Riso RZ220 Duplicator
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
I want to change my security keyguard code for nokia 2700 classic phone. version is 09.98 and other detail is RM-561... pls help
If you want to change your security code you need to change it in the mobile itself. If you forgot the security code then you can try 0000 or 1234 other wise get the Master Reset Code.
Jun 25, 2012 | Cell Phones
Due to applying wrong security code of nokia 2700c-2 type 561 Code 0579319 IMEI:353376048892886 fcc id:qtlrm-561 BECOME LOCKED plz how can i unlock ma phone???
sir my cell phone is not working due to country code please tell me the country code i purchase my cell from japan and now i want to use it in pakistan
Jun 27, 2011 | Nokia Classic 2700 Cell Phone
I'm getting an error when trying to install the driver for the NuVue 561 digital picture viewer. This is the first time it has been used. Any assistance is appreciated. Thanks!
Can you please tell me what kind of error is occuring? What does it say? I suggest you, without knowing the problem, to reinstall the driver and then, to restart the computer.
May 12, 2011 | Spectrum NuVue 561 (U30333) Digital...
Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
Jul 02, 2010 | Audio Players & Recorders
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Xerox Workcentre 5330/p 5330 Mono Advanced Multifunction Copier/printer/scanner Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
