Question about Maytag Dishwashers
Model#MDBH969AWS1 will not do anything except, blink a service code on clean light (7 blinks)
Ser#F02611710
the dr
  • 447 Answers
SOURCE: whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Posted on Dec 23, 2007
SOURCE: not working
Solution #3 is good, but you need to hit "High Temp Wash" and then "Heated Dry" back and forth 3x to reset the computer.
Posted on Oct 13, 2008
  • 188 Answers
SOURCE: clean light blinks 7 times continuously
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on May 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
SOURCE: Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Whirlpool dishwasher model# gu2200xtss3 normal light flasing all the time turning power off does not help in a few minutes back on flashing
The light blinking is an error code--usually it will blink a certain number of times, pause, then blink another sequence(ex. 4 times, then 3 times)in a binary error code. There is a chart in the service manual to decipher the code(s) and locate the issue. It could be anything from a heater circuit failure to the drain pump being jammed. Try to see how many times the light blinks, and which ones blink--there could be, on the first part of the sequence, normal light, then, 2 or 3 lights blink-- I need to know which ones are lit. Thanks! You can try to look up the light combinations on the net with a search for your model number and error codes.
Oct 12, 2015 | Whirlpool Dishwashers
Clean light blinking will not start
Count how many times it blinks before it pauses and repeats. If it's 7 times, then it is a very common problem, and you can find the solution by searching for "dishwaser clean light blinking 7 times".
Nov 03, 2014 | Kenmore Dishwashers
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
What does it mean when my clean light blinks but I cannot cancel or reset it
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller.
Jul 21, 2014 | Kenmore Dishwasher With Ultra Wash And...
Reset control panel
If the clean light blinks 7 times and pauses,you have a problem within heat circuit,inspect the element for cracks or breaks.The actual door latch could be out of alignment also find the latch and bend it downward ever so slightly to assure good connection at door switches. To clear code push hitemp-airdry-hitemp-airdry,this will allow you to run cycle if code comes back,you may need servicer.
Apr 03, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
I have the kitchenaid dishwasher model #kudv03ctss0.the clean light stay blinking and when i hit the start it just blinks and then stops but the clean light stay blinking constantly.if i hit the cancel...
Dear friend,
ngfam at you service! happy to assist!
It's an electronic problem!
The lights are called codes and need to be diagnoed by a factory service person!!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Dishwashers
Doesn' cycle power is on except drain cycle goes, clean light blinks 7 times
Check this link for more info:
http://www.repairclinic.com/0088_9_1.asp
Jun 17, 2008 | Dishwashers
Dishwashers Logo
280 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
