Question about Arris SB5102 SURFboard Cable Modem
Motorola sb5102 bridge mode mac airport - Arris SB5102 SURFboard Cable Modem
What is airport mode on a Galaxy Notebook phone?
Airport mode stops all calls coming in and you ring out.
Sep 07, 2014 | Computers & Internet
I need to download a Win7 Motorola SB5102 cable modem driver via this XP laptop
Yes, you can do it.
Downloading the driver will result in a file you can copy over to the flashdrive.
Just do not double-click on the file, because that will start the installation process.
In the unlikely case that the file auto-starts the installation process, you will normally have the option to Cancel the installation.
May 07, 2014 | Arris SB5102 SURFboard Cable Modem
I've connected my airport extreme by ethernet to my modemrouter Thomson TG585 V7 in bridge mode, as soon as i connect a speedtest on either machine drops by half, disconnect the airport and the tomson...
Simply put, a bridge evenly splits bandwidth, a monitor will, to measure, run upload/download tests by transmitting data which is EXACTLY THE SAME as downloading or uploading data to any other server. Brain engage.
Aug 04, 2010 | Apple Computers & Internet
Can you help with apple airport extreme networking?
What kind of help do you need? That's a big topic! Describe to us your environment that you have . . . who is your broadband provider? What kind of Macs do you have? I have ATT uverse. I disabled their wireless ( slow ) and then added my Airport Extreme in bridged mode on the WAN side. On the LAN side, I chose an SSID, and 'created a network', and set the protocol to B/G with WPA/Personal authentication. It seems to work just fine . . .hope that helps!
May 21, 2010 | Apple AirPort Extreme (AIRPORTEXTREME)...
Cant find the RESET button on the SB5102
the Surfboards do not have a reset button. The only sure way to reset it is to disconnect the power and any other cables for at least 12 hours to allow the board to completely discharge.
Mar 07, 2010 | Arris SURFboard SB5120 Modem
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
I want ot disable DHCP on apple extreme router. Because MS 2008 SBS R2 scans for DHCP servers and fails to config if found an other dhcp server (apple extreme)
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
Mar 16, 2009 | Apple AirPort Extreme Router
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Arris SB5102 SURFboard Cable Modem Logo
63 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
