Question about Audiovox SIR-PNP3 SIRIUS Radio Receiver
No Display All of the sudden, my display is no longer working. The unit plays music without a problem. I can press the preset channels and that works. This happens in both my boombox and my car. Any suggestions??? Would hate to have to buy another. Only had this one for 1 1/2 years!
  • Andrea Grlica Jul 11, 2007
    Thank you, Duncan. But this is a Sirius Satellite receiver. I take it from my car to a boombox at home. The display is completely dead. Don't know if there are lamps, fuses or whatever. That is what I am trying to find out. Even if I open to figure this out, don't know what I am looking for. Trying to find someone that knows exactly what I need to repair and where it is located within the receiver.
    Sergeant:
  • 279 Answers
What you need to look for is the ribbon cable Duncan mentioned. It should be the only cable that goes from the screen to the main board (the largest electronics board). That cable should be fairly easy to spot once you have the case open. If that cable is disconnected or torn at all, that's your problem. You said it's completely dead, which means it's not a bulb or the lamp (which is too bad, because those are easier to replace). Unless that ribbon cable is loose or damaged, this will not be cost effective or at all easy to repair. In that case, it will be cheaper to replace.
Posted on Sep 05, 2007
    Novelist:
    Champion:
  • 219 Answers
On your car, see if you can see even a very very faint display if you view it at just the right angle. If so, you have a display backlight that has failed or burned out (if it uses lamps). Replace the lamps and you are good to go. If your unit in your car is a flip face then you may have a bad wire in the ribbon cable that connects the face to the mother board. This can be replaced fairly cheaply. Good luck with your unit.
Posted on Jul 11, 2007
  • 203 Answers
Sounds to me like the display went bad on you. I'm not too sure your those though.
Posted on Jul 10, 2007
  • Benjamin Madison
    Benjamin Madison Jul 10, 2007
    I'm not too sure you can get one of those separately though.
I have to reset the radio in my Nissan xtrail. I have the code and have put that in . The last number keeps flashing and the radio still doesn't work
Not sure if you've reset it before but here are the directions. Pay attention to last paragraph.
If you have done this sorry for not having another answer.
The trick is to know that only the channel preset button labeled 1,2,3,4 are used to enter the PIN - each channel button is used to increment the value of one digit on the display. Channel preset '1' increments the first digit, '2' the second, and so on. Each press of a channel button increments the corresponding digit by one, cycling back to 0 and around again.
So to enter 1924 as a PIN, you'd start with the display reading '0000' and press
- preset 1 once (increment 0 -> 1)
- preset 2 nine times (increment 0 -> 9)
- preset 3 twice (increment 0 -> 2)
- preset 4 four times (increment 0 -> 4)
The last one's easy, as the radio unlocks as soon as you hit the right code so you just keep pressing preset button 4 'til it unlocks! (i.e. it's a 4 digit PIN but only as secure as a 3 digit one.
Feb 06, 2018 | Nissan Cars & Trucks
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
My denon 3313 will not play the channels from my pandora account it sees my play channels it wont play them
Have you checked to see if there is a firmware update? You might need to reset back to factory but you will loose any items you put in.
Factory reset by:
1 Turn off the power using ON/STANDBY.
2 Press ON/STANDBY while simultaneously pressing PRESET CHANNEL 2 and PRESET CHANNEL 3.
3 Once the display starts flashing at intervals of about 1 second, release the two buttons
Mar 26, 2014 | Denon AVR-3313CI
Audio System Problem
Check wiring maybe some of wires have worked loose.
Mar 11, 2014 | Toyota RAV4 Cars & Trucks
Hi i have ford festiva 95, on the radio only err is blinking, i tried to put code but does not working, i know the code but how should i enter it
Leave it SWITCHED ON...UNDISTURBED until it has automatically reset itself.
Ford Code EntryInstructions Once the unit has been turned on the display will show 'CODE - - - -' Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit To save the code press the [ 5 ] key to accept. The set should now operate. Enjoy your music. =====================================
Feb 24, 2011 | 1993 Ford Festiva
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
on the TV screen.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
channel reappears on the screen.
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
Radio display says SAFE and will not play music
You need your radio code its 4 numbers, you use your radio preset station button to change the # press the 1 station button till you put in your code then the # 2 preset station # then 3, then fourth preset. You should find your code in your service manual. when your code is in, press the + or - button on the station search, or refer to your manual. good luck
May 12, 2009 | 2002 Volkswagen Cabrio
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
Audiovox SIR-PNP3 SIRIUS Radio Receiver Logo
235 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Andrew Taylor
Andrew Taylor
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
