Question about Coleman 10' X 10' Sundome Tent 9160K101
Coleman dual fuel lantern won't work
The lantern was plugged up, no fumes. Now it spits out raw fuel and the fumes do not reach the mantels..
I need an manual detailing the proper way to put it back in working order.
  • Anonymous Apr 15, 2009
    I have a old colman liquid fuel lant. that will not send fuel to the mantels .. i tried everthing. new fuel new pump removed the valve the open and close valve. NO LUCK PLEASE HELP.
4 Suggested Answers
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
  • 234 Answers
SOURCE: coleman lanterns as collectibles
Coleman Collectors Guide 1903-1954.
Tucker & Ebebdorf
ISBN 0-9651407-0-9
This is an excellent reference with lots of pictures etc., it does not give the prices, however.
You can check Ebay for completed prices if you need an idea of value.
I have not found a book yet with accurate values on Coleman lanterns.
Posted on Apr 21, 2009
SOURCE: how to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Posted on Nov 06, 2009
My coleman powerhouse dual fuel lantern brightens and dims continuously. could this be the generator acting up?
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
Sep 21, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
I have a dual fuel, two mantles, coleman lantern. I have changed the mantles several times and they keep getting holes almost every time i light the lantern.
Make sure that the vapourised fuel is coming through the mantle before lighting up. You should hear a hissing sound when the flame adjusting lever is turned to high. If not it is possible that the generator is clogged up and that vapourised fuel is not getting through to the mantle. So when you light up you are essentially just burning the mantle. If the generator is knackered it will need to be replaced. One way to check it to remove the generator, primed the tank and turn the valve on. If fuel spurts out when the generator is removed (DON'T LIGHT IT U)P THOUGH) but there is no hissing sound when the generator is intact then it is a sure sign that the generator is clogged up. In the UK a replacement generator should set you back £10-15. Hope this helps, Bandit
May 23, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
I cant get any petrol to pump into the mantles
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Jan 03, 2011 | Coleman Northstar Dual Fuel Lantern
My coleman dual fuel lantern wont let me pressure the fuel up with the plunger
Remove the plunger and oil the leather diaphram with light oil similar to 3 in 1 oil, and expand the diaphram until it is no longer stiff and contracted. If you do not know how to remove the plunger let me know.
Sep 16, 2010 | Coleman Cable Coleman Twomantle Dual Fuel...
How to light coleman lantern
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
I require a manual for a Duel Fuel lanterm Powerhouse
This manual is a poor quality but hopefully it helps! Interestingly enough, the U.S. Coleman website does not post this manual but the Australian site does:
Coleman Powerhouse Dual Fuel / 2-Mantle Lantern Model 295A700 Manual:
http://www.colemanaustralia.com.au/SiteFiles/colemanaustraliacomau/manuals/dual%20fuel%20lanterns.pdf
Apr 29, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
How to fit a mantel to a coleman propane lantern
Mar 16, 2009 | Coleman Camping, Backpacking & Hiking
Coleman 10' X 10' Sundome Tent 9160K101 Logo
296 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
