Question about Pool & Spa
HL display on my hot tub
I have an arctic spa and the read displays "HL" and the unit pump and heater will not turn on
5 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: Arctic Spa refill and a heater alarm ''HL''
You may have a Spa Builders control system which was commonly used by Arctic Spas throughout their range.
Turn the hot tub off at the mains to reset it. If 'HL' returns again on the display you need to feel the heater tube. If the heater tube is not hot either, you have most likely got a faulty hi limit temperature probe (attaches to the heater), or a faulty PCB.
It might also be wothwhile checking the hi-limit probe connection on the PCB, these have been known to corrode and cause errors before.
The temperature probe is the cheapest item so try replacing this first.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
PartsCenter
  • 125 Answers
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Posted on Feb 26, 2009
  • 3 Answers
SOURCE: Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Posted on Mar 12, 2009
  • 19 Answers
SOURCE: pool and spa heater will not turn on, low pressure on display
1) check the fuse on the transformer. You will get "low pressure" if the fuse is blown.
1a) remove front panel with flat head screw driver turning both big screws 1/4 turn clockwise
1b) look up under the 1 remaining front piece for 2 screws (one on each side). remove them and the 1 small panel slides down
1c) transform is directly in the center of this compartment
1d) red wire on transform has a black fuse case - twist open and check fuse (with an ohm meter it should read a dead short if it is working).
1e) if not working - replace with standard 250v 2a bus fuse.
2) it really is low pressure
2a) backwash pool or at least make sure pressure in filter take is not too high (high filter tank pressure == low water pressure in heater)
2b) if you have a bypass valve make sure it is not in bypass mode so most all pressure from the pump is going tothe heater
2c) right next to the transformer is the pressure switch. It has a small copper tube attached to the back and 2 wires in the front. Put an ohm meter across the two leads on this device. With the filter off it should be open, with the filter on it should be closed (short). If not either the copper tubing is clogged, the switch is faulty, or there is not enough water going through the heater. The amount of water that goes into the heater is adjustable and the water pressure switch is also adjustable. The owners manual explains how to adjust both but neither should need adjustment unless you have a special configuration (explained in the manual).
Posted on Sep 20, 2010
I have a orca bay hot tub just replaced upper display now says hl
replace the High limits or make sure recirculation pump is working
Aug 27, 2014 | Pool & Spa
My Apollo Rainier hot tub's heater doesn't seem to work - I get a FH message on the display. Please help!!!
HL generally stands for high limit fault which means a sensor is opening the heater circuit due to too high a heat reading. Common causes for such a fault start with poor water flow due to dirty filters which in turn allow the element to overheat. If necessary, replace the filter elements to restore proper flow.If flow issues are not the problem, try looking at the heater itself however you should probably call out a professional at this point as most remaining issues to check are within the controls and the heater and if you are not familiar with working on these components you should avoid trying to repair this yourself.
Oct 22, 2011 | Pool & Spa
What does HL on display panel mean
Thank you for posting your question here on Fixya.com.
HL stands for high limit...it means one of the high limit switches is open, preventing the heater from working. Either the limit has failed and replacing it will correct the issue or there is a situation with the heater or flow rates causing it to truly overheat...fixing the issue will return the heater to operation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 23, 2011 | Arctic Pool & Spa
I have a 2003 Arctic spa and have changed the heater. I have a HL sensor error on the panel but the tub is cold?
HL usually means that the heater is working and there is no water passing through it, do you get a flo error message before the HL,I had the same problem, mine was the flo switch
Oct 08, 2010 | Pool & Spa
HL displayed on digital control panel Aruba 1060
Jamie ...
Please do not sit in a tub that is, or claims to be, above 100 degrees F - unless there is a trained, licensed doctor or therapist watching you. 108 is deadly - don't find out by accident.
I think there is something seriously wrong with your tub - you need a pro to look at it. Your tub should not heat above 100 and it should only heat if the pump is running. If it is heating with the pump not running, it will quickly burn out and possibly cause other, expensive troubles.
Thanks for your interest in FixYa.com
Jun 07, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Dec 28, 2008 | Arctic Above Ground Rugged Mesh Winter...
Pool & Spa Logo
664 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
