Question about Microsoft Windows 98 for PC
Boot failure does not boot after switching the computer
  • 156 Answers
- Please check HDD Cables
- Check the RAM (Switch off system, remove RAM, Reinsert it and restart).
- Reinstal OS, if it does not work.
- if it fails remove partitions using diskmanager, recreate them and reinstall OS
Zulfikar Ali
Posted on Jan 24, 2009
Can not boot up computer
possible your hard drive
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Tip
How to isolate issues between hardware and software
<p>It has been one of the dilemma of computer users is to identify what is really causing the failure in their computer. Often they think that they bought a defective product since they are getting these kind of errors in the computer. Having an error on your machine does not mean that the machine is defective or needs parts replacement. for all we know it might just need some simple troubleshooting steps to fix the issue. Here is a tip where you would be able to know if you need to bring your computer to a service shop for parts replacement or you can try to fix it at home by doing some troubleshooting steps that would help fix software failure in the computer system.<br /> <br /> On a Windows based operating system, you should always know when the issue happens. It will help much to observe your computer on how it boots up and what it does before you get to the desktop screen. Take a note on where and when exactly the error occurs.<br /> <br /><b> Power Failure:</b><br /> <br /> This is an issue where there are no lights on the power button of your computer, whether it is a portable system or a desktop computer. Obviously this is a hardware failure. surprisingly, discharging the flea power of your computer sometimes resolves these kinds of issues. Otherwise, you will definitely need to have a local technician look at your system for parts replacement.<br /> <br /><b> Note:</b> flea power is the charged power of our computer system. A computer system is made up of electronic components such as capacitors which hold electronic charges. To be able to discharge it, you should disconnect all power source from your computer and hold the power button for at least 5 seconds.<br /> <br /> <br /><b> POST Failure:</b><br /> <br /> POST is an abbreviation for Power On Self Test. as the name implies, it is the test that a system goes through to test the basic hardware components needed for a computer to boot. The components that it tests are as follows: Processor, BIOS (Motherboard), Memory, keyboard and video card. If there is a POST failure, the system would give you a black screen with lights on the front panel. Sometimes it will give you beeping sounds which would normally mean that you have a memory failure on your system. If you encounter such issue, you will need hardware technical support to guide you isolate further on what could be causing the failure.<br /> <br /><b> Boot Failure:</b><br /> <br /> Boot failure is when the computer is able to complete post. You will be able to know this if you hear a single beep on your computer. Isolating a boot failure from a post failure simply requires you to boot to the System Setup/configuration Screen (BIOS). If you are able to get to the BIOS, that means all the POST hardware component are good to go. However, booting to the BIOS differs per system. You just need to do trial and error on the following keys to tap as you turn your computer on.<br /> <br /> Del<br /> F1<br /> F2<br /> F10<br /> F9<br /> ESC<br /> <br /> To isolate an issue whether it is a software or a hardware issue, you just need to boot from the BIOS. If you are able to boot from the BIOS, chances are it is not a hardware failure and needs servicing.<br /> <br /> <p><img src="vincent_von_0.jpg" /><br /> <p><br /> If booting to the BIOS works, to further isolate the issue whether it is the advanced software, you need to boot to Safe mode. Safe mode is a troubleshooting state where only the basic applications and drivers are active. If you are having errors or boot failure, try to boot to Safe Mode. If you do not encounter the failure in Safe Mode, that means that there are advanced software being loaded in your operating system that fails. It is just a matter of knowing what that software is.<br /> <br /><b> Booting to Safe Mode:</b><br /> <br /> 1. turn computer on and tap on F8 before Windows starts.<br /> 2. You will be getting the Advanced Boot options. Use the arrow keys to get to the option for Safe Mode.<br /> <br /> <p><img src="vincent_von_0.png" /><br /> <p><br /> <p><br /><b> Safe Mode Definitions:</b><br /> <br /> Safe Mode: Just basic software are being loaded. Network drivers are not included which means no internet connection<br /> <br /> Safe Mode with Networking: Basic software and Network drivers are being loaded.<br /> <br /> note: for Vista or Windows 7, it includes wireless network drivers. This means that you can still connect to the internet with a wireless connection. In Windows XP, the wireless driver is not included even if you boot to Safe Mode with Networking<br /> <br /> Safe Mode with Command prompt: this is a troubleshooting state where you will be able to utilize DOS based commands.
on Jul 15, 2011 | Computers & Internet
Media test failure message. Reboot and Select proper boot device
hope this helps
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Boot failure
Check the connectors running to your hard disk to make sure they are firmly connected. Also check the data cable to the motherboard. Reboot the computer and enter BIOS. Check that your hard drive is being detected properly. If it is not, the drive is shot and needs to be replaced.
May 29, 2009 | Intel Pentium III , 900 MHz Processor
Disc read error
This appears due to some range of possibile problems. Try following these steps: 1 ) Boot the system > goto BIOS setting (press DEL or F2 as soon as u switch on the power switch) > check the boot sequence somewhere in that settings and choose to "boot from the harddisk"     This has got some 50% probabily of solving the problem.
2) If not, you have to reinstall the OS using a operating System CD. Put the CD in, boot up and follow the on-screen instructions to reinstall the OS.  DONT FORMAT IT - you will loose all ur data. Just reinstall it. SOme boot sector files might hav been corrupted. Reinstalling the OS will surely solve ur problem. Thankyou!
Mar 27, 2009 | Envision EN 9110 19" Flat Panel LCD...
Regarding boot failure
If you can boot with a Windows 98 floppy boot disk, then do so, you need to run scandisk. It is also possible that your hard drive has failed, you can go into the bios and see if it is being recognized.
Jul 20, 2008 | Microsoft Windows 98 for PC
Disk Boot Failure
you need to select ur harddisk as the first bootable device., that option is in BIOS settings. When switch on the system before loading OS press F2 to get the BIOS settings and select boot option in the menu and select your harddisk as the first bootable device. Restart the system now. If the same error is displayed your harddisk data cable may be failed or your harddisk may be corrupted...
Jul 11, 2008 | Computers & Internet
Computer will not turn on
The only things that can do this are: A card failure, a hard drive failure, Motherboard faiulre, A Power Supply failure, Faulty RAM. To toubleshoot.. disconnect Hard Dive, CD/DVD remove any & all cards, see if it boots,if it does, add the Hard Drive, reboot, then add the CD/DVD, reboot, then replace A card, reboot & so on... until ya find the faulty component, that stops it. If it doesn't remove ram & see if it powers up, it will NOT boot. If it doesn't ya PSU is most probably faulty. If it does ya RAM/motherboard is faulty. So basically strip it down see if it powers up. than add things one at a time to find the culprit.. then replace the ofending item.
Aug 06, 2007 | HP Compaq Ethernet Switch
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
