Question about Pantech C300 Cellular Phone
How to disassemble a pantech c300
Comment by BIGMAMA1600, posted on Jul 10, 2007 Your answer seems very helpful but there is one other problem. I was trying to disassemble the phone but the screw heads are so small I do not have a screwdriver small enough to fit the head. I tried using the screwdriver that comes with an eyeglass repair kit nd even that was not small enough. Where can i find a screwdriver that could fit the heads of the very small screws in this C300? ________________________________________________________________________ ______________Best Solution posted on Jul 08, 2007 ´┐╝ By Priority1 Rank: Master Rating: 78.18%, 11 votes How wet did it get? Was it submerged? The backlight would normally shut off after a short idle period or when you close the cover. If it is staying on all the time after water damage then there is still water in a component (like a capacitor) or corrosion that has opened or shorted a circuit path somewhere confusing the phone. There is a good chance that corrosion will become worse and do more damage. New problems could arise any time in the next few days or few years. If this were my phone I would disassemble it and clean it with rubbing alcohol, toothbrush, and air duster but there is some risk even for someone experienced. Also, microphones can be damaged by fluids including rubbing alcohol. ___________________________________________________________________________________________ posted by BIGMAMA1600 on Jul 08, 2007 Report abuse MY CELL PHONE GOT WET. I USED A BLOW DRYER AND PLACED IN A BOWL OF RICE FOR A FEW HOURS. THE PHONE WORKS BUT THE BACKLIGHT IS STAYS ON WHERE THE FLIP IS OPEN OR CLOSED. HOW CAN I MAKE THE BACKLIGHT GOT OFF (IF THAT IS POSSIBLE)?
  • Matt Jul 07, 2008
    How do I disassemble my Pantech C300? It has recently suffered some
    water damage and so I want to take it apart in order to clean it with
    rubbing alcohol. I got the four screws off from the back side
    underneath where the battery goes, but the phone will not separate. It
    seems to still be connected near the top. Is there a way to take it
    apart?
I used a micro screw driver set that can be purchased at Home Depot. There are two hidden screws: one on the top piece where the display is and one on the bottom piece where the keyboard is. The hidden screw on the top piece is under a silver rubber circle at center bottom of piece. The hidden screw on the bottom piece is under a silver rubber water drop shape located by the antena. These rubber covers can be removed by wedging them out with a mirco flat screw driver or pin.
Good luck...
Posted on Aug 02, 2008
How do I disassemble my Pantech C300? It has recently suffered some water damage and so I want to take it apart in order to clean it with rubbing alcohol. I got the four screws off from the back side underneath where the battery goes, but the phone will not separate. It seems to still be connected near the top. Is there a way to take it apart?
Posted on Jul 07, 2008
How do i unlock pantech c300?
If your phone purchased in USA on or after 26 January 2013, please contact your network/service provider and get their permission to unlock your phone with a help of third party online unlocking service provider.Using network unlock code is the best way to unlock your Cingular locked Pantech C300 mobile phone.If you need an unlock code visit Classicunlocking.com Here you can unlock your mobile phone within a day.
Apr 03, 2013 | Pantech C300 Cellular Phone
Need unlock code for pantech c300 cell phone
You can get Pantech C300 unlock code from third party sites or you can request that pantech unlock code from your network provider but you still need to pay some charge from them.
Apr 09, 2011 | Pantech C300 Cellular Phone
I need GPRS & MMS settings for my Pantech c300....i am located in the Philippines.
Well you need to contact costumer care of your service provide only they can send you the GPRS and MMS settings, they send you a message of GPRS and MMS settings you just need to save that message to your phone....... So call now to your service provider costumer care and ask them for that settings........ Post comments if you need further help or information........
Note. GPRS, MMS or Internet settings are always provided by the service provider....
Good Luck!!
Mar 27, 2010 | Pantech C300 Cellular Phone
Pantech C300 MMS settings for T-mobile
Hi I have the same phone my mss works but my internet wont. Here are the settings you need. If you have the internet settings please post in return. Thanks!
Profile Name: T-mobile mms
Home URL: http://216.155.174.84/servlets/mms
Connection Type: WAP
GPRS Settings:
- Gateway:
IP Address: 216.155.50
IP Port: 9201
- Access Point: wap.voicestream.com
- Login ID: Blank
- Password: Blank
Bearer: GPRS Only
Feb 04, 2010 | Pantech C300 Cellular Phone
Pantech c300 **** on headset mode with no headset connected
my phone got a bit damp and had this problem, after a whole day of only being able to text i separated it from the battery and blow dried it, it was no longer stuck in headset mode when reassembled.
Mar 08, 2009 | Pantech C300 Cellular Phone
Text Message Help: Pantech c300.
Maybe you have no sevice, or you might not have any minutes left on your phone.
Aug 24, 2008 | Pantech C300 Cellular Phone
Pantech c300
My pantech c300 wont't turn on or charge, why??
May 17, 2008 | Pantech C300 Cellular Phone
Speaker
Hi kamibu - I don't know if anyone has gotten back to you or not. I apologize if they haven't. I could explain what you need to know but I believe it's easier to look at the manual with the pictures. Below you will find a link for your manual. Once again I apologize for the delay. It's the first I knew of it. If this solves your problem PLEASE rate this as fixed. If you already have it don't rate. If you need more help just add a comment and I'll be happy to assist you further. Thanks much.
http://www.wirefly.com/resources/phone-manuals/pantech/Pantech_C300_Manual.pdf
Jeff
May 10, 2008 | Pantech C300 Cellular Phone
Pantech C300 [camera]
GO TO OPTIONS AND PRESS SEND THEN ITS GOING TO ASK YOU NUMBER OR E-MAIL
Jul 14, 2007 | Pantech C300 Cellular Phone
Pantech C300 Cellular Phone Logo
5,994 people viewed this question
Top Pantech Cell Phones Experts
Marvin
Marvin
Abdul Mannan
Abdul Mannan
rebecca curry
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
