Question about Vacuums
Red light comes on after charging my ergorapido
Electrolux ergorapido plus
Christmas 2013 I was given an Electrolux ergorapido. I put it on the charger and red light won't come on or if it by chance does it flashes three times and then cuts off.
Aug 13, 2013 | Vacuums
I have a 2 year old Electrolux ergorapido cleaner that gets used daily for about 2/3 min, the blue light on the stand comes on when the cleaner is put on to charge but fades after about 5 min & the...
No, not worn out batteries.
For my experience, if the batteries were worn, they would charge with the blue led being on and after that, the vacuum wouldn't hold his charge. just that.
This is a different problem. Check the contacts between the charging station and the vacuum, mines got bent a bit and stopped making contact. This has happened twice and just fixed it about 30 min ago. That is why the led first lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
Jan 21, 2011 | Electrolux Vacuums
Do i keep my ergorapido charged all the time when not in use?thank you
you can if you want to but in order to get the best of it when useing it you should keep charged
Dec 29, 2009 | Electrolux Vacuums
My electrolux ergorapido wont power on . Have only used it a few times. It has been on the charger for approximately 2 weeks without use.
If it will not come on there are several things you need to check. First off you should call and have your model type and serial number checked to be sure your unit isnt affected by the recall they had due to expanding batteries. Second you do have a 2 year warranty on the unit and if it wont even turn on there may be a defect. Are the blue charging lights coming on? If they are and your transformer is warm then there is more then likely a defective battery in the unit and you should contact customer service at 1800-896-9756
Jul 18, 2009 | Black & Decker AV1200 DustBuster Handheld...
Ergorapido: light doesn't come on when vacuum is put on charge
If it is new, take it back and get a different one, either the charger or the battery is bad.
Mar 26, 2008 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
