Question about Sony Walkman D-EJ100 Personal CD Player
How do I get my My Sony Walkman D-EJ100 to play? The batteries are ok.
2 Suggested Answers
SOURCE: sony cd walkman D-EJ100 troubleshooting
There is a switch on the bottom of the unit that puts it in "HOLD" mode. My guess its for use when it is shipped so there will be less chance of damage. Try switching the two position switch to the other position.
Posted on Nov 14, 2009
Sony Walkman D-EJ100 Personal CD Player: eats batteries even when not in use. I listened to a CD for 20 minutes, stopped, and a pair of new AA batteries were dead 4 days later. Is there a way to shut
Probably suffered damp ingress while in storage, and thus some conductive internal corrosion; use a test meter to see if there's any leakage when it's switched off and take it from there...
Either that or use AA Nimh rechargeable batteries
Nov 24, 2014 | Sony Walkman Audio Players & Recorders
I have connected an adapter of 4.5V with Sony Walkman, i am receiving an error "HI DC IN". Let me know the problem.
hi,
check the out put voltage of that adapter may be its out put is higher than 4.5V dc.
thats why the Walkman displays HI dc IN. do one thing purchase a 4.5V 1amps SMPS adapter (connector with same polarity). it will give a constant output of 4.5v (110v t0 240v input)
ok
Jan 19, 2011 | Sony Walkman D-EJ100 Personal CD Player
My sony N50 won't play and reads no disc when htere is one in it. The batteries are fine
It is quite possible that your optical unit is faulty. First of all clean the lens on the optical head using an ear bud, softly rub for a good glazing. then try to see if it works if not the lens unit assembly must be replaced and must be done with care and experience.so take help to replce but make sure the cost is within a practical level. Good day
Aug 09, 2010 | Sony Walkman D-EJ100 Personal CD Player
My sony walkman wont play videos!!
try using a diffrent converter like the arcsoft media converter that one has worked well for me just make sure you convert it to wmv
Mar 01, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sony cd walkman D-EJ100 troubleshooting
Aug 11, 2008 | Sony Walkman D-EJ100 Personal CD Player
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
Blinking "disc" error
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Nov 01, 2006 | Sony Walkman D-EJ100 Personal CD Player
Sony Walkman D-EJ100 Personal CD Player Logo
51 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
