Question about Dryers
SIMPSON EZI SET 350
HEATING OF AIR DOES NOT WORK EVERY THING ELSE OK
5 Suggested Answers
SOURCE: Simpson Sirocco 350 Dryer not heating
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Posted on Feb 25, 2009
SparkyNZ
  • 43 Answers
SOURCE: when the dryer is on high or medium heat, it trips the power breaker of the house. it does not do this on air only/no heat", which makes me think of a short in heating unit.
the dryer is run by a universal motor, and these motors (while being very robust) can draw more current if the torque put on the drive train is overloaded. try running dryer with less clothes.
Posted on May 12, 2009
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Posted on Sep 20, 2009
SOURCE: Where does the spring clip
Hi, I too have one of these dryers & have also found a spring, along with alot of fluff, some staples, & remains of the rear seal inside the dryer. must be a manufacturing fault by the looks of things, the spring was bent & twisted & must hold the seal in place. I would say it will need to go to the repair people for replacement. also note the fluff (remains of the seal) had an area where it had burnt from the heating element & could cause a fire.
Posted on Mar 31, 2011
My Simpson ezi sett 7.5 always fills to full even when set to low. i have replaced the pressure switch and still fills to full.
Check the rubber hose from the pressure switch down to the bowl for any holes or splits allowing the air pressure to escape. Also check that water valve is stopping the flow. Start to fill then press pause. Water flow should stop immediately. If it keeps flowing or is slow to stop then replace the inlet valve. Try it several times to be sure.
Dec 18, 2016 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Where do I locate the filter on clothes dryer - simpson ezi set 350
The filter is located inside the dryer at the back of the drum. There are two holes that you can pull on to release the filter.
Here is a YouTube video that shows where the filter is located.
https://www.youtube.com/watch?v=E3r7J5j_I14
Nov 27, 2013 | Washing Machines
Hi My Simpson EZI set 7.5kg washing machine has an error 'Ed' and it wont go
That means it is having issues draining. PLease check the filter on the pump and make sure that the drain hose is ok.
Aug 31, 2013 | Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
I have a Simpson EZI Loader 5.5kg, where is the lint filter
HI just read your posting.Now the SIMPSON EZI LOADER comes in front and top loader versions.Which type is yours?Are you getting a lot of lint on your clothes?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 03, 2010 | Washing Machines
Hi, i have an Simpson Ezi Set 950 - Top Loader that im looking at bying online that needs a part 4 runing order, just wondering if u knw if and were i can get the part witch is (main Bearing) for it and if...
Hi just read your posting.Now how old is this Simpson.When I have replaced bearings in the EZI SET range of washing machines I always have to change both bearings and the main seal as well.Can you tell me why you need to change this bearing,Is the machine noisy on spin?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Washing Machines
Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Aug 03, 2009 | Electrolux Washing Machines
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
