Question about Epson Perfection V500 Flatbed Scanner
Photoshop CS6 won't see scanner
Photoshop CS6 can't find Epson twain
sherlyn c
  • 134 Answers
SOURCE: Epson Perfection v200 stopped working on my imac
Try to scan using epson scan to isolate the issue. You can launch epson scan from applications. If you can scan using epson scan, call adobe to troubleshoot further on photoshop.
If you get an error epson scan cannot be started or if it won't launch. It could be connection or driver issue.
To uninstall/re-install twain on mac, follow the instructions:
- go to applications. Trash epson scan and epson scanner monitor
- Go to library then application support. Trash epson scanner module.
- Go to library then image capture. Trash twain data sources.
- Go to the hard drive. Click on user. Click on the name of your computer. Click on library. Click on preferences. Click on epson. Trash epson scan.
- Empty the trash.
- Restart your mac.
- Log on to support.epson.com. Type in v200 in the search box on the top right corner of the page then click search. click on the first search result. Click on the drop down box and select macintosh operating system instead of windows. click on the second driver down, epson12527.dmg then click on download now. Select no thanks, i prefer not to receive this information then click accept. Install the epson scan installer after the download.
- Then try to scan using epson scan.
If epson scan won't launch or you get an error, try a different usb cable.
Goodluck.
sherlyn c.
P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; }
Posted on May 22, 2009
SOURCE: Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Posted on May 27, 2009
  • 35 Answers
SOURCE: Can't use the ''Film selection on epson V700
Make sure the transparency light cable that comes from the lid is plugged in to the back of the scanner. If the cable is unplugged for any reason, the transparency/film options will not be available.
Posted on Jun 14, 2009
xptareq2000
  • 1447 Answers
SOURCE: Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Posted on Aug 27, 2009
SOURCE: I am unable to scan
Ok usually to scan films one needs a special attachment, or fitting, as you can't normally scan negatives, they come out all overexposed or underexposed etc. Anyway, if this component is absent, then the scanner will detect this and you will not be able to scan them... using that setting anyway.
You need to find out, what's required to do what you want...once all setup i should think you will have no problems..
If you can't get or don't want to have to use the/any adapter, there are "Other' various ways to using a normal scanner and a bit few tricks, one can indeed scan film... You need to Google this if it's what you want.
Posted on Dec 15, 2010
Adobe photoshop CS 6 extented serial number
Download new fresh adobe cs6 keys:
http://downupfiles.com/file/0r88674
Apr 18, 2013 | Adobe Photoshop CS6 Extended - Windows
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
I need a autorized code for adobe photoshop cs3
If you mean the serial code for Adobe Photoshop CS3, you can no longer buy Photoshop CS3. If you want you can buy Adobe Photoshop CS5, because it is the current version. If you need CS3 specifically, you can might be able to find one from a friend or possibly from a pawn shop.
Jul 28, 2011 | Computers & Internet
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
How do i select the destination of a scanned file ie photoshop using epson scanner tx550
Firstly, the best way to get more from the scanner is to use it via an image application which is twain compatible e.g. serif photoplus, photoshop or gimp. Run the program, click file, then either aquire or import depending on the application you are using, the twain will then start the scanner software, use the scanner software as shown in the manual and this will produce the scanned image in e.g. photoshop. Click file on the program and click save as. This will give you the opportunity to save the file either onto the internal hard drive or an external memory stick etc. hope this helps
Jul 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Using adobe photoshop 8 the editor will import from my Epson Perfection 1260, but the organiser will not get from it displaying "Epson perfection 1260 software for this device could not be launched the...
I don't think it's any of those things. I think it's a Twain Data Source problem. When you install the software for your scanner, make sure you also install the twain data source files. This is the scanning protocol used by all scanners and if not present, the scanner won't import images into Photoshop under the command "File" -> "Acquire."
Mar 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Scanner no longer works
Check in Control Panel>Scanners and .... if it is listed.
If not check the ink level is recognized. If not check seetings of the printer port.
Try also to scan from an picture editing program like PhotoShop. File>Import>Epson Stylus® DX4850 - twain.
Mar 05, 2010 | Epson Stylus DX4850 All-In-One InkJet...
Epson perfection application not working on G5 10.5.8
hi there. you actually downloaded the right driver :
try this Run Photoshop in Rosetta mode; Epson Scan 2.77A only runs in Rosetta mode.
Follow the steps below to run Photoshop in Rosetta mode:
  1. Open the Hard Drive, select Applications > Adobe Photoshop, then select the Adobe Photoshop icon.
  2. Hold down the drv_mac_407_er.gif-I keys to open the Get Info window.
  3. Check the Open Using Rosetta option, then close the window.
  4. Start Photoshop.
Dec 23, 2009 | Epson Perfection 1250 Flatbed Scanner
WANT TO INSTALL ADOBE PHOTOSHOP
hi there!
thanks for using fixya!
here you go, you may download adobe photoshop from here:
http://www.adobe.com/support/downloads/product.jsp?platform=windows&product=39
Regards!!
Pls don't forget to rate me with my solution!! thanks!
Feb 25, 2009 | Adobe Photoshop 7.0 for PC
Serial number ng adobe photoshop cs2 plssss......
Hey i found this great new site offering Adobe Photoshop Serial Numbers for all versions, here's the link:
Adobe Photoshop Serial Keys - All versions
I hope this helps...
Oct 28, 2008 | Adobe Photoshop CS2 for PC
Epson Perfection V500 Flatbed Scanner Logo
123 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
