Question about Xerox WorkCentre 5325 5330 5335 Black Toner 006R01159
Reset tray setting - Xerox WorkCentre 5325 5330 5335 Black Toner 006R01159
HP 4350 with a 41.3 error- Paper size is set correctly and size switch actuator is OK. I tried another tray and also tray 1 (manual feed tray). That tray jams- no lift to feed roller. Any ideas?
I have seen many diferent 41.3 errors. Start by making sure tray is set to standard instead of custom and reset machine to factory settings. Next change out the roller assembly behind the tray 1. It has the selonoid on it. I have seen that cause it before. I would just replace the entire tray 1 to solve the no lift. good luck
Apr 08, 2013 | HP LaserJet 4350 Printer
It says to reset paper tray. How do i reset it?
Hello sir; On the left top on your cintrol panel there have a key said "user mode", press this key,then touch on screen "copier setting" then looking for tray setting , reset all tray,.
Jul 13, 2009 | Ricoh Office Equipment & Supplies
HP P3005N printing from Tray 1 and not Tray 2. Paper is in TRAY 2 but still gives message to use Tray 1. Only way to use the printer is to use Tray 1 at this time.
Do a cold reset and the paper trays will reset themselves, it's the easiest way. Turn printer off, turn the printer back on and as soon as you see the memory starting to count push the check mark button and HOLD IT until you see all the lights stay on. When they stay on, and you see "select language", push the arrow button until you see "cold reset", and push the check mark button again. You will be all set.
Jul 13, 2009 | HP LaserJet P3005n Printer
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
How to reset the settings
Use the bypass tray for A3 or any tray which can also be adjusted to take A3.To adjust the tray, extend the green lever to the place indicated as A3 on the tray then load paper and on the control panel or key panel , press the paper key and hold until it blinks while the rest is off, use the paper select key to adjust to A3 and press print key, then press the paper key again.
Apr 21, 2009 | Sharp AR-5320 Black and White Copier
Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
Mar 24, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
I have a hp laserjet 4100n and everytime i print it keep telling me that manualy feed plain letter paper but I wanted to automatically print on tray 2 which it does not, I know my settings are wrong if it...
The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page:
MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT.
The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to check the paper back stop in tray 2.
The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray.
Or the arms on the tray that operate the switches are not moving properly.
You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps.
Mar 04, 2009 | HP LaserJet 4100n Printer
Tray 1 is full on my Sharp AL-1642CS but when it ties to print to tray 1 the 'P' keeps flashing!
pull both trays out.....have a look in tray 2, is there a switch sensor actuator hanging down yes........is there a similar one in tray one?
No? They get knocked off and lost very easily
Jun 11, 2008 | Sharp AL-1642CS Copier
Holding the Reset button for 60 seconds didnt help!!!!!!
Unlike the suggested solution to reset to factory settings by pressing the stop button on the DVD player itself with the tray OPEN, in my case I succeeded only with the tray CLOSED (no DVD inside). The light flashed to red e back to green and it was done.
Jan 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
Nov 30, 2007 | HP LaserJet 4350 Printer
Xerox WorkCentre 5325 5330 5335 Black Toner 006R01159 Logo
20 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
