First Bios pro Extract Tools - Computers & Internet
Do you have bios flash file (bin file)?
http://www.lg.com/lgecs.downloadFile.ldwf?DOC_ID=KRSWD000003451&ORIGINAL_NAME_b1_a1=UL1F3G41_UI.zip&FILE_NAME=KRSWD000003451-b1-a2.zip&TC=DwnCmd
DOWN LOAD BIOS FILE EXTRACT ZIP FILE AND INSIDE EXTRACT EXE FILE WITH WIN RAR AND RENAME UL1IA32.FB FILE AS UL1IA32.BIN
IT IS BIOS BIN FILE
May 05, 2014 | LG X130 Netbook
Bios password unlock
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
May 05, 2013 | Toshiba Satellite Pro 465Cdx...
Son forgot password on acer netbook how do i reset to an earlier time?
Download "ERD commander", below is the link
Rapidshare Link
Megaupload Link
Easy-Share Link
You can use any of the above link. Extract the file using Winrar and burn the ISO images in a CD.
Boot your system using that CD (Set the first boot device as CD-DVD Rom in your BIOS).
You can easily set a new password using the tools called "Lock Smith"
That's it.
Feb 03, 2010 | Computers & Internet
How do you update the serial number in the BIOS
This is *NOT* a question about an ACER Travelmate LCD display.
The "short" answer is "you cannot", without the proper tools,
namely the tools to physically remove the BIOS chip from the motherboard, and a 'PROM-burner' device, to extract the contents
of the BIOS (about 2Mbits of data), update a few bits, and then
to "program" the updated data back onto the PROM (Programmablel Read Only Memory) chip, and then reinstall the BIOS chip back into your motherboard.
Good luck! Always "experiment" with a "test" motherboard, rather than first goofing-up your "production" motherboard.
Jan 09, 2010 | Acer TravelMate C300 14.1 XGA LCD Display...
What are the compatible BIOS for intellistation Z PRO 6223 work station
Here is the link to your system BIOS tools and updates:
http://www-947.ibm.com/systems/support/supportsite.wss/supportresources?categoryind=5050379&selectedButton.x=12&selectedButton.y=13&selectedButton=category&familyind=5050008&brandind=5000004&osind=5053379&typeind=5178890&modelind=0&matrix=Y&taskind=2
Dec 17, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
My Bissell all pro does not extract water from carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
zcvzcv
Jul 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Want to updat bios for xp
Operating system doesn't have an effect on the bios update process. Simply you can go online and search for your motherboard's website for BIOS flash utility, and new bios files. And through that website, you can follow the instructed steps and update your BIOS. (For example: Asus Mainboard Model P5GD1 Pro -> Go to Asus international website and select your mainboard model, you can find the tools and updates related with your particular model there). You just have to look up for your mainboard's complete brand and model name first.
Apr 14, 2009 | Computers & Internet
Gateway solo pro 9300 bios password is not remove
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.This is a better way
Dec 15, 2008 | Gateway Solo 9300 Notebook
I am looking for win xp sata drivers for my toshibe satellite pro
Download Matrix storage manager, all the instructions on how to downgrade to XP are there.
These are the drivers you need:
iaAhci.inf, iaAhci.cat,
iaStor.inf, iaStor.cat,
iaStor.sys, TxtSetup.oem.
readme.tx and license.txt
read the readme.txt its important!!!!!!!!!
Nov 12, 2008 | Computers & Internet
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
