Question about Kenmore Dryers
Dryer drum or rollers or bearings are squeaking on my Kenmore 970-C69042-00 clothes dryer. How do I best trouble-shoot and repair it?
  • 314 Answers
Instructions
    • 1 Turn off the gas to a gas dryer or unplug an electric one. Move the dryer from its position at least 3 feet from the wall. This will give you room to work. Pulling the dryer out into an even more open space may make this easier.
    • 2 Push the putty knife in between the top and main body of the dryer on the front of the dryer. Slide the putty knife near the corner closest to you. Push the knife and pull up to release the pins that hold the top onto the body.
    • 3 Lift the top off the body using a screwdriver as a lever.
    • 4 Label the wires that are connected to the front of the dryer. Make note of which wire goes where. Unclip the wires from the clip that holds them, remove the wires and place them to the side. You will be reattaching these wires later. Be sure to mark them so that you can place them back in order later.
    • 5 Remove the screws that hold the fount of the dryer onto the rest of it. There should be four on most models.
    • 6 Pull the front towards you until the drum inside comes loose from its bearing. Slide the front panel up to reveal the pulleys at the bottom of the machine.
    • 7 Grab the idler pulley. It is the one in front of the motor. Move it to the right to disengage the belt. Remove the belt. Do not remove the belt that goes to the drum.
    • 8 Put on your gloves and slide the drum out of the dryer. Be sure to use hand protection as the edges may be sharp.
    • 9 Inspect the two rollers. If they appear damaged, or you find metal dust under them, your rollers need replacing.
    • 10 Remove the plastic clip on the right hand side if the right roller needs replacing. Remove the metal friction plate, metal brace and plastic clip on the left hand side if the left roller needs replacing.
    • 11 Put on the new rollers and reattach the parts you removed.
    • 12 Slide the drum back in and grab the idler pulley. Pull the pulley to the left until the belt is tight.
    • 13 Slide and screw the front into place and reattach the top.
Posted on Jan 15, 2013
  • 210 Answers
SOURCE: squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
Posted on Jun 03, 2008
Illeagle
  • 525 Answers
SOURCE: dryer squeak
Your issue is as follows;
"My G. E. dryer make squeaking noise when the drum is turning. However, it only during so, when load with cloths."
Based on the information provided above, I am unable to access my database to provide you with exacting information. You did not provide a valid model number, however, I have provided some common solutions to help guide you in your search.
My Solution is:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Following the link below will provide some information on G.E. dryers.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=784658&PPStack=1
Following the link below shows disassembly procedures for most G.E. models.
http://www.repairclinic.com/0100_20.asp
Rear drum bearing: Most common failure Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 17, 2008
  • 126 Answers
SOURCE: NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Posted on Jan 07, 2009
kachbibi1
  • 979 Answers
SOURCE: Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Posted on Jan 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Posted on Mar 07, 2009
I have a kenmore 70 series electric dryer that squeals or squeaks when you start it and will squeak periodically during the drying cycle. From what I can tell the actual model number is 66702692 or 110...
hello there and welcome to fixya
There is several areas that you will want to check and listen to it carefully
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 01, 2011 | Kenmore Dryers
Model 8600 , drum makes loud noise, not a squeak
HI,
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Jul 26, 2008 | Maytag Dryers
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
Kenmore Series 70 electric dryer 66702692 Dryer makes sluggish sound when hit start button./ Dryer heats up and does dry clothes for up to 5 minutes at best then shuts off. Typically shuts off...
Hello there:
please use this troubleshooting list i have pprovided below to help troubleshoot the problem and let me know how this is going ok
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 06, 2010 | Kenmore Dryers
Dryer has a squeaking noise. does it need to be
Change the belt and check all of the bearings for play. If any have too much slack replace them.
Jun 23, 2009 | Dryers
Dryer makes a squeaking noise
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
thanks and please do not forget to accept the solution
Apr 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Metallic squeaking from Amana Dryer
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Good luck.....
Mar 28, 2009 | Amana Dryers
Kenmore stackable washer/dryer...dryer making HORRIBLE shrieking sound while drying...any ideas?  don't have dryer #
Hi
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 84052 Dryer
Jan 25, 2009 | Kenmore Dryers
Squeaking kenmore dryer
Hi .thanks for the question. the noise is from the drum rollers . you can buy a drum roller kit for kenmore dryer . to repair. lift out lint screen remove 2 screws . with a flat screw driver pry the top up between the top and front at each corner. lift top 2 screws on the inside of front panel remove pull front off . remove drum . replace parts in drum repair kit . thanks the appliance doc
Oct 03, 2008 | Kenmore 63012 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
