Question about Vulcan 60L Gas Kitchen Range
Vulcan 8 Burner Range, Pilot goes out when oven reaches temp
Basically the pilot lights completely fine, and i turn oven to 500 degrees and everything works fine but when it reaches temp, and the burner shuts off, the pilot also goes out.??? please help........ model number 481LC
    President:
  • 1,990 Answers
Welcome to Fixya! This sounds a Lot like the Gas Preassure Regulator on the line that comes out of the Wall. If it is not Sending enough Pressure and gas, It will blow out the Pilot light Everytime.
Posted on Jan 24, 2009
Need an owner manual for Wolf 6 burner Model CH-4-29-FT11
Try Googling (wolf)(CH-4-29-FT11)(manual) without parens.
Jun 11, 2017 | Kitchen Ranges
When I turn the oven down the gas goes off and have to start again
read the user manual as the temp should be thermostat controlled were with gas there is always a pilot light burning when the oven is in use and when the set temp is reached the gas burner is shut off and when the temp fall below set point , the gas is turned on again and the pilot light starts the burner
by using the timer , when the time is reached the gas is turned off and of course you will have to relight it
if you do not have a user manual , download one from google or talk with a gas repair shop
Sep 18, 2016 | Belling Ovens
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
After oven reaches desired temperature, it has late ignition that turns off the pilot AND OVEN WILL NOT STAY ON.
Sounds like the pilot is mounted to far away from the burner. I have seen it happen before where the pilot has detached and the main burner will just keep pumping gas in until it hits the pilot flame and just flash flames and everything goes out.
Or it just could be a bad thermocouple that is going out all the time.
Mar 01, 2013 | Southbend S36D 36" 6 Burner Gas Range,...
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
Vulcan 148L oven burner will not light. pilot on. should pilot flame touch thermocuple?
Yes.
Over time, thermocouples erode in pilot flames and when they no longer reach the pilot light they need to be replaced. Check the thermocouple mountings as well: some ham-fisted amateurs try to bend the probe back into the pilot light and break the mountings. The pilot light jet will also need to be checked to ensure that it is clean and that the pilot is burning correctly.
Note that as with all gas appliances, repairs should only be carried out by qualified gas fitters who have the tools and knowledge to leave your appliance in a safe condition. In many countries it's a legal requirement. My reply is therefore given on an informational basis only as poor workmanship on gas appliances is directly attributable to many deaths every year.
Mar 16, 2010 | Kitchen Ranges
One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Feb 23, 2010 | Vulcan Kitchen Ranges
I have a 6 burner Vulcan stove with a bad oven pilot light.
Hi! I have the same problem with one of my burners (I have a morice range). I changed the thermocouple, but it didn´t help. I contacted Morice in France and was told that the problem most sertainly was the coil inside the gasvalve. I don´t know if it possible to dismantle the ovengasvalve to check the coil. As for a burner valve, one should open the valve at the end were the gas goes out to the burner to locate this coil. Best of luck Lars?ui=2&ik=305879aaef&view=att&th=1244dff9c340942f&attid=0.1&disp=thd&zw
Oct 06, 2009 | Vulcan 36L Gas Kitchen Range
Oven pilot light is on, but burners will not light. pilot light burns larger when trying to turn burner on. Do I need a new thermostat?
The thermostat is doing it's job if the pilot gets bigger. When you turn on the thermo, it does 2 things: Makes the pilot bigger and supplies gas to the oven safety valve in the oven. The bigger pilot heats up the bulb from the valve and the stuff inside expands and turns on the main gas. The oven cycles when temo is reached by making the pilot smaller. The most common problem is that the pilot doesn't get big enough to satisfy the valve. Take out the pilot burner ***'y. (7/16" wrench for the nut). Replace the pilot burner. The part is probably a 5414S030 if the valve bulb is located parallel to the ***'y.
Sep 30, 2009 | Magic Chef 31000 Gas Kitchen Range
I have a ef3 vulcan, when reaches temp, the pilot goes out.
Set the thermostat to 350 degrees,get a thermometer and put it in the oil,when the unit shuts off look at the temp of the oil.If the temp of the oil is higher then the thermostat is bad if not the hi-limit may be.Let me know.
Apr 04, 2009 | Vulcan EF3 Deep Fryer
Vulcan 60L Gas Kitchen Range Logo
145 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
