Question about Kenmore series 80 Washer Motor 3363737-
I have a kenmore 80 series washer and a newer Estate dryer. I had a ring in my jeans front pocket and accidently washed it still in the pocket. Didn't realize it until the clothes were dry. Loo
Not sure where else to look or how to go about looking any where else.
  • Kenmore Master
  • 17,130 Answers
Could be found in the drain filter , please check on this link for tips to remove the filter/pump
click on filter
Posted on Jan 15, 2013
SOURCE: Kenmore 90 plus series spin dry is not working
In resposnse to guest Dec 29th - I read further and later tested the lid switch. That did the trick. Thank you for the information contained on this site: not only did it save me a service call, but my wife was ready to purchase a new unit. Thanks to all those that have contributed in the past, your knowledge is invaluable to the do it yourselfer. C.F.
Posted on Dec 29, 2008
onthejob5130
  • 640 Answers
check your lid switch...bad lid swich...
Posted on Jan 17, 2009
SOURCE: Kenmore 80 series spins but won't ring out clothes
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Posted on Mar 06, 2009
SOURCE: kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Posted on Mar 19, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 70 Series Washer won't spin or drain
DO NOT by pass a lid switch. It is installed as a designed safety feature to prevent bodily when opening the lid from moving parts. The CORRECT solution is to replace the switch. The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Replacements can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best deals. The first two web sites have excellent exploded view diagrams of your appliance to aid in parts location and assembly.
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
PS This is not a difficult repair and it doesn't cost much ($25 to $35) on average for a replacement switch. Begin, fisrt by making sure the switch isn't loose or the lid strike (if equipped) isn't broken off. You may not need parts.
Posted on Jul 26, 2009
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
Kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Kenmore 80 washer that spins but clothes are still too wet...
to me this sounds like a clutch,
or possibly worse, your transmission that is spitting oil onto your clutch
lift the front of the washer and check to see if there is a puddle of oil on the ground. if so, its most likely your transmission. and a clutch would be a temporary fix
but if no puddle, it is most likely just the clutch that needs replacing
May 26, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Washer/Dryer
I HAVE SEEN MOST MARKS COMING FROM THE DRYERS. AS THEY AGE, THE FELT AIR SEALS ON THE DRUM DETERIORATE AND THE CLOTHES GET PINCHED BETWEEN THE DRUM AND THE BULKHEAD AT THE REAR OF THE DRUM. OTHERWISE CHECK THE HOLES IN THE WASHER TUB IF YOU HAVE A PORCALIN ON STEEL TUB IN THE WASHER.
Jan 26, 2009 | Washing Machines
Tub leans to the right when washing the clothes
I washed pillows in my washer and now the tub leans to the right front. And my dryer needs to have the lint cleaned out of it. How do I do this. They are Kenmore 80 series washer and dryer
Nov 23, 2008 | Maytag HAV3460AWW Top Load Washer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Whirlpool ultimate care II lost item in washer or dryer
It is most likely that they are in the dryer if you still have not found them. Please respond with the type of dryer that you have and I should be able to assist you in opening your machine for a good look. From what you have describe it sounds like you have an Inglis or speed queen dryer.
Feb 27, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore series 80 Washer Motor 3363737- Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
