Question about Hardware & Accessories
Orbit timer Model No. 94133 - Hardware & Accessories
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
Need a manual for an orbit model#27752
Orbit 27752 are most likely solenoids. If you are after a manual for a timer then you may need to clarify which model it is. You could refer this Orbit site and directly download whatever you are after.
Orbit Irrigation
Aug 26, 2014 | Hardware & Accessories
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Aug 09, 2012 | Orbit Hardware & Accessories
Hardwire the orbit outdoor sprinkler timer
Reset the timer? This will sometimes resolve many problems.
Are you sure the conduit has 120Volt? Is the timer connected to single breaker?
Or is circuit 240V? Timer connected to double breaker.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
What do you mean green wire to negative?
What else is on the conduit circuit?
Motors, fluorescent lights, and other electronics can interfere with electronic timers.
Run extension cord to timer from another electrical source and see if problem continues.
Re-post question with model number so timer-electricity expert can read the troubleshoot section of manual.
http://waterheatertimer.org/pdf/Rona-91026-water-timer.pdf
Aug 01, 2012 | Orbit Hardware & Accessories
I'm trying to find instruction manual for Orbit 58872N withuout success, could you help me?
Copy following link for several orbit resources.
Many Orbit manuals cover more than 1 model number.
Jul 21, 2012 | Hardware & Accessories
Directions for GreenThumb watering control by Orbit model 27157
Copy following links for Orbit timer manuals & sprinkler timer manuals
Jun 08, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
