Question about Whirlpool LEW0050P Electric Dryer
Need to replace dryer belt.
My daughter put a heavy rug in her small stackable dryer, and snapped the belt. I have purchased a new belt, but cannot figure out how to route the belt on this unit. The parts diagram shows the belt around the drum and the drive motor shaft, but the new belt will not come close to reaching over the motor shaft. Any help will be appreciated!!!
  • Anonymous Apr 11, 2009
    My belt is not broken but must have slipped off motor. Taking this dryer apart to put belt back on motor is much more difficult than larger models I owned.
  • 547 Answers
Screw on bracket of motor for tentsion release
Posted on Feb 12, 2009
Belt replacement on Kenmore Dryer.
The first thing I do is remove the top. Then I drop the splashplate and remove the controls. If this is the first time you have messed with it their are some zipties that need to be removed. then the controls unplug and the control panel is set aside. The drum is real heavy. If you are 10 feet tall Tarzan you might can get it out by using the belt to assist you after you have removed the idler. A trick is just remove the 3 screws to the rear drum bearing and get the drum out. Then re-attach it to the drum before you install the drum back in the dryer.
Assorted dryer service manuals and more
Aug 30, 2012 | Kenmore Dryers
The Drive belt of my ;G Tumble Dryer snapped. I bought a new belt and need to learn how to replace it. Can the expert explain to me, step by step how to replace it in a safe and efficient way without...
put the new belt onto the small pulley or drive pulley first- you will then be able to turn the belt onto the larger pulley by turning it by hand . All of this is done with power off and plug pulled out . good luck
Jul 21, 2011 | Dryers
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Maytag stackable dryer
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool stackable dryer was working and stopped. Sounds like it's getting power when the button is pushed - Won't start/spin. The belt has been screeching for some time. Assume the belt has snapped or...
stacks vary, you may be able to access between washer and dryer... there is usually a panel there, but some do have the large acces panel in the back and yes you can access the belt... watch your fingers aroound the motor because when you put a new one on, the tension is very tight
Feb 22, 2009 | Dryers
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryer stopped
some dryers have a switch thats attached to the tension pulley for the belt. if the belt breaks the dryer wont start. if the rug got stuck it probably broke the belt
Nov 25, 2007 | Dryers
Whirlpool LEW0050P Electric Dryer Logo
209 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
