The compressor and fan come on at rear. when I press the turbo cool button the frezzor fan comes on .press the button a second time it gives a EE reading at the display.
The evaportive fans are not comming on.I just replaced the cover evap assembly and the fan motors still dont come on.
The problem started out that the refrigator was not cooling. I noticced the evaportive coil was froze up. I assumed it was because the evap fans were out.
What would be the repair salution.
Luke
Hi and welcome to FixYa,
On most instances, it would be the fan motor (most likely). Considering its size and the 'extreme' temperature for its working condition, the small motor (bearings) are subjected to internal stresses.
However, in some rare instances, it would be the controller board (for this problem least likely).
To verify, you need to be able to check the presence of voltage supply to the fan motor or do a blind repair, that is just replace.
Pls post back results. Godd luck and thank you for using FixYa.
Welcome to Fixya! The last time this happened to mine, I Replaced the Heater Relay Behind the Inside back Freezer panel after Defrosting the Coils and have had no More Problems Yet. Been about a Year now.
The ER of course stood for error and the EE indicates it was in the freezer fan motor. There was no fan motor signal for more than 65 seconds. This can be caused by a bad motor, bad connections to the motor or something obstructing the fan blade.
